P0171 system lean code on K20A
Old Dec 18, 2008 | 01:24 PM
Rishiras's Avatar
Default P0171 system lean code on K20A
Guys,
I got my Euro R accord from japan, however In japan the chek engine was ok.
As soon as arrived I got it with chek engine light, scanned it , cleared it twice, comes on after a while, SYSTEM LEAN ON BANK 1>code P0171, anyone recalls what that means?
Would it be that when unloading from ship, the 02 sensor on bottom got hit or something?
Please help !!1
R
Old Dec 18, 2008 | 03:09 PM
ekb16's Avatar
did u try putting in higher octane gas
Old Dec 18, 2008 | 04:27 PM
philafelman's Avatar
we have a bulletin out at work at toyota for bad A/F sensors causing a p0171...just did one the other day.
Old Dec 19, 2008 | 06:51 AM
Rishiras's Avatar
Old Dec 19, 2008 | 06:53 AM
Rishiras's Avatar
I have just fueled the tank with normal pumpgas unleaded, since car came with 1/4 tk from japan. ECU light was on from unloading of vessel,so not after fueling.
when idling for 15min, after Ecu light has been resetted, the ECu light comes on.and give same code P0171.System to lean bank 1.
I will be cheking the parameters, 02 sensor, fpr, etc
Old Dec 19, 2008 | 04:18 PM
definitely a good place to start looking...see if your primary oxygen sensor is stuck. from what ive seen, this usually causes the car to run extremely rich to compensate for what it sees as a lean condition.
Old Dec 19, 2008 | 06:24 PM
tech7427's Avatar
check for a biased o2 sensor, not crosscounting.
be sure to check cam lash as well. for the sys too lean code to set the STFT has to be over a certain threshold, and the o2 sensor is what tells the pcm to control fuel trim.
how many miles are on this engine?
Old Dec 20, 2008 | 12:43 AM
Rishiras's Avatar
car is in extreme good condition, with only 49.900km, the primary 02 sensor will be the one in the pipe on the bottom of the car? or the one above in engine bay at headers?
Old Dec 20, 2008 | 10:00 AM
the one that is closest to the head...so the one in the manifold.
Old Dec 20, 2008 | 07:18 PM
Rishiras's Avatar
aight thx, i will chek it, take it apart and clean with contact cleaner, then i will reset the ECU.and let u know.thanks so much
Old Dec 21, 2008 | 08:31 AM
Rishiras's Avatar
Default Re: P0171 system lean code on K20A
problem solved, primary o2 sensor cleaned with Contact cleaner, inserted and cleared ECU light with SCantool, ecu stays off, thanks guys !!!
efcivic2dr
Apr 1, 2008 09:20 PM
classciv
May 8, 2006 10:43 AM
huntarrr
Sep 24, 2005 11:46 AM
kimo98GSR
Jun 30, 2004 09:51 PM
stockintegra
Mar 27, 2004 02:13 PM
