Car turns off after driving v.2
Old Dec 18, 2008 | 09:21 AM
dorkzracing's Avatar
Default Car turns off after driving v.2
So, first i was having problems with my car turning off after driving it and it wouldn't turn back on till like 15mins later. I was suggested to replace tha distributor so i did. The car ran fine for about two days and then it started turning off again when i'd be driving, but this time it would turn back on on the first crank.
This are the items i've replaced
- Fuel Pump
- Distributor cap and rotor
- Distributor
- p28 ECU (it had an AUTO ecu so i picked up a stick shift one)
- Sparkplugs
- Distributor cables
- Main Fuel Relay
- Relay box
- 02 Sensor
I don't know what else to do!!!
Other important info: My check engine light was on saying that my 02 sensor was bad so i replaced it. The car has a JDM d15b with OBD0-OBDI harness jumper.
Old Dec 18, 2008 | 11:32 AM
anyone?
Old Dec 18, 2008 | 11:36 AM
greyrex's Avatar
You had the same symptom with my rex but it was fine after i had my distributor replaced and i'm currently waiting for a new dizzy unit from distributor king.
By the way,my check light turn up and says it's the map sensor issue during the problem occurred.
Note: Do a check on the harness jumper.
Old Dec 18, 2008 | 11:38 AM
LoidBanks's Avatar
try your main relay
Old Dec 18, 2008 | 11:40 AM
after i fixed the 02 sensor CEL i didn't get any more codes.
I already checked the jumper harness but i'll check it again.
Originally Posted by LoidBanks
try your main relay
i did. it's brand new
Old Dec 18, 2008 | 11:44 AM
greyrex's Avatar
Did you installed any fuel regulator?
Old Dec 18, 2008 | 12:41 PM
crxjarred's Avatar
is ur tank cleen
Old Dec 19, 2008 | 07:11 AM
no, Do i need to?
Originally Posted by crxjarred
is ur tank cleen
Gas tank? i haven't checked it
Arshia Rezaei
Jan 11, 2013 10:10 AM
civicsi_5289
Aug 25, 2008 09:36 PM
riftonthemind057
Mar 27, 2008 01:08 PM
ECICivic
Apr 3, 2005 04:51 PM
DALE-EK4
May 26, 2002 07:52 AM
