turbo kits
i have a 1997 honda prelude it is a european model right hand drive it has a f20a sohc non v tec engine is there turbo kits availible for this engine or would the turbo kit for a f22a engine do the trick
everybody will likely advise you to piece your own setup together. You pretty much just need a list of everything you need. I think most of the time if you shop around you can get it cheaper than it would be in a kit anyway!!
