Fuel rail fitting?
Ok, i checked out the article on http://www.hondaprelude.to/install_fuelline.html and i ordered part # EAR-982268 and it turned out to be the wrong one... Can someone please tell me what thread pattern and what 90deg earl fitting to use for AEM fuel rail?
Picture belongs to member: SilverLudeSi (i think...)
Sorry about that. I'll change the article right now. I still don't know what part you'll need, I was misinformed by the first guy I got information from. Unless they've changed the rails since then. Let me know what the end fittings turn out to be and I'll add them back in to the article.
I spoke with silverludesi and he informed me the fittings on the AEM fuel rail are -6an fittings. I will double check this tomorrow and let you guys know whats the deal.
i ordered 3" 180deg 14gauge DynoMax mandrel bent piping from summit racing for $18.50 a piece, part # WLK-42323. One U-bend should do the trick to make the whole downpipe, depending on the lenth of straight you need. I have a local welder here that is a GREAT welder and he is going to custom fabricate a 3" dp as well as exhaust for me so ill post pics when its all finished. Im also running a 3" flexpipe, no cat, no resonator, and apexi n1 turbo muffler.
Loud as in ricy sounding? I hope not... It better have a nice low deep throaty sound. The exhaust housing is a 5 bolt, there are 5 bolt flanges for these, let me know if you need one. Only thing is, they dont have the gasket for it, so im making one out of some good material i got from work.
I have a 5 bolt flange with a 3" downpipe and it fits fine. I am also running 3" all the way with no resonator, no cat, and a magnaflow muffler - it isn't that loud at all.
thats good to hear, i didnt think it would sound bad. are you running a gasket bw the exhaust housing and the downpipe? thanks for the info
[Modified by GudeH23a, 9:11 PM 8/7/2002]
