Milling head and Block, questions..???
Old Aug 3, 2002 | 06:32 PM
C4wrx's Avatar
Default Milling head and Block, questions..???
i blew my head a couple weeks ago, i picked up a new head and slapped it on, when we put it on oil came out of the block.... so its a little warped, whats a safe amount the shave off of the block, and also the head, and also what kind of compression will i be running from doing this when its done, i have a b81c1, with stock pistons and im going to be using a stock honda head gasket.. any info on the pros and cons of doing this will help. thanks in advance to the honda-tech members
Old Aug 4, 2002 | 01:52 AM
C4wrx's Avatar
Default Re: Milling head and Block, questions..??? (Jdmb18c)
no one can help?
Old Aug 4, 2002 | 08:15 AM
earl's Avatar
Don't mill anything unless it is warped. Have a machine shop check the head for flatness. The motor will have to come out to do the block. Leaking oil not necesarily a head gasket. You could have installed the head gasket upside down or backwards, could be a valve cover leaking, vtec selenoid leak, etc.
Old Aug 4, 2002 | 08:34 AM
C4wrx's Avatar
Default Re: Milling head and Block, questions..??? (earl)
we checked the block and it is warped just a little bit on the 4th cylinder
Old Aug 4, 2002 | 09:18 AM
non-VTEC's Avatar
take it to a good machine shop and have them only remove the ammount needed to bring it back into spec.......no more......
Old Aug 4, 2002 | 10:21 AM
earl's Avatar
Default Re: Milling head and Block, questions..??? (non-VTEC)
Yeah, if u take too much off it messes up your timing and timing belt.
Old Aug 4, 2002 | 06:15 PM
C4wrx's Avatar
aright guys, thanks for the input, the block is out and heading to the machine shop on tuesday
and one more question, some peopel said milling your head is bad in the long run? why is this? or is it not true, will my head not last as long if i mill it, i was goign to have it milled 30
Old Aug 4, 2002 | 06:23 PM
earl's Avatar
Mill as little as possible..weakens everything and throws timing belt out of align.
88 EF Hatch
11
Jul 16, 2009 10:14 AM
Nisif
Nov 21, 2005 01:55 AM
sickerhatch
Mar 1, 2005 03:19 PM
ITR_1211
Jan 5, 2004 09:04 PM
