losing power with mpfi swap.. help pleaes
Old Dec 17, 2008 | 07:05 PM
classdork987654's Avatar
Default losing power with mpfi swap.. help pleaes
i did the mpfi swap on my d15b1 a few weeks ago and it ran great. then i noticed the fuel rail had a small leak by the fuel dampner or the nut the tightens down on the fuel rail. i took it off and noticed that i had one of the washers mixed up. so i fixed all of that and now it runs but when i give it gas and put a load on it, it loses power and sounds really deep? a friend said it could be fuel pump? and i already changed the fuel filter and that actually made it worse? help please. also i have a new pump just its snowing out so if i dont need to change it yet i dont want to lol..
Old Dec 17, 2008 | 07:25 PM
~sp33~'s Avatar
EFB055
Sounds like your timing? Has that been correctly adjusted?
Old Dec 17, 2008 | 08:07 PM
EFRue57's Avatar
it's not gonna be your fuel pump i don't think. it's either gonna work or not work. if it's working then your car will start, if not then it won't. there's no really in between with those things. check some simple things first like maybe your spark plugs. if your timing is off like ~sp33~ suggested then maybe you fouled them out or something which would make your car run sluggish.
Old Dec 17, 2008 | 08:34 PM
ya it probably is the timing cuz i took the dizzy off and when i put it back on i could barley get the car to move. but since then i retimed it and now it runs just gettin up to speed on the freeway is slow. it also threw code 1. thats the o2 sensor right? would that be from it not being in time?
Old Dec 17, 2008 | 09:38 PM
i hav it timed with the pointer right on the middle marking of the three? is this ok? still learning about timing
Old Dec 18, 2008 | 03:52 AM
~sp33~'s Avatar
EFB055
Where you setting the ignition timing? Or your valve timing?
Old Dec 18, 2008 | 09:42 AM
i believe it was the ignition. i was moving the dizzy. could the valve timing be off?
Old Dec 18, 2008 | 04:21 PM
~sp33~'s Avatar
EFB055
If it was running fine beforehand then i doubt it's off now. Do you have a timing light? If not just try adjusting the dizzy a bit then go for a drive, see if things improve.
Old Dec 18, 2008 | 11:55 PM
ok thanks. the only thing i never figured out was when i changed the fuel filter the car could barely drive.
thewhite_ricer
11
Jun 5, 2009 06:54 AM
classdork987654
Jan 1, 2009 01:16 AM
brian3676
Dec 31, 2005 09:58 AM
xtegb16x
Oct 30, 2005 12:20 PM
