LAM Performance Raffeling OFF a Motor+More
We are going to be raffling off this motor.
the motor is currently posted upforsale but got this idea and see how this works out.
entry fee is $20 per .
you may enter as many times as you would like.
we will not be taking any money at this time if you would like to enter pm me and I will post a list to and keep updating .
when we see that this is going to take off we will sart collecting money and setup a day to pick the winner
first we will start for just the motor+ecu only when we reach so many entries we will add more stuff .
this will be posted on many site other then tampa racing,
when the day comes to pick the winner we will host a meet at a park and do it live and record it infront of everyone
if the winner is out of state he/she will have to pay shipping charges
Engine:
B18C5 (ITR) block
stock rods/crank
ARP rod bolts
Weisco 12:1 pistons(w/ wrings and wrist pins)
all new bearings/ thrust washers/ seals gaskets.... everything
NEW ITR oil pump
New GSR water pump
CTR N1 crank pulley
Gates racing timing belt
ARP head studs
B16 head
JG engine dynamics dual valve springs
JG engine dynamics Titanium retainers
Toda Spec B cams
B16 intake manifold that has been cut open and ported throughout, and the runners have been shortend
HyTech replica header W/ 2 1/2" straight back to magnaflow muffler
all solid motor mounts W/ hasport Front motor mount
Transmission:
93 ls cable tranny no grinds, shifts perfect nice and tight.
Clutchmaster's light weight flywheel
brand new axles with lifetime warranty.
Tampa clutch supply Dual friction clutch disk(4 puck kevlar/metallic sprung hub)
Tampa clutch supply pressure plate
Honda MTF fluid
p28 Tuned with NepTune
2step
and a 2nd map for Nitrous for 75 Shot
pm me with name and how many time you would like to enter your self
entries
1.b18_da X2 times
2.Ls_[eg]hatch
3.sled1
4.Bite_Size X3 times
Engine:
B18C5 (ITR) block
stock rods/crank
ARP rod bolts
NEW ITR oil pump
New GSR water pump
CTR N1 crank pulley
ARP head studs
B16 head
Toda Spec B cams
Transmission:
Honda MTF fluid
2step
entries
1.b18_da X2 times
2.Ls_[eg]hatch
3.sled1
