Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
New Clutch question
Old Dec 17, 2008 | 04:02 PM
ajpturbopittsburgh's Avatar
Default New Clutch question
I will be putting in a new clutch on my 01' ex sedan. It has 103k and I think the last one was put in at 50k . This car is a daily driver and not modified and never will be. Should I get an aftermarket or go with an oem honda clutch? I want long life. I will be getting a flywheel too.
I have to let it out really far before it grabs and it chatters abit. It still holds fine and doesnt' slip at all
Old Dec 17, 2008 | 05:01 PM
It Wasn't Me's Avatar
You don't need anything special. An OEM spec replacement should be sufficient.
Old Dec 17, 2008 | 05:22 PM
ejLday's Avatar
yea I would go oem hands down
Old Dec 17, 2008 | 05:32 PM
Targa250R's Avatar
be professional
Honda uses Exedy/Daikin as original equipment; you can save a lot of money by buying what are essentially the same parts aftermarket from Exedy rather than from Honda. A stock replacement Exedy/Daikin clutch is inexpensive and reliable.
If it still holds fine without slippage, I'd continue driving on it for now. Mild chatter is just an annoyance caused by hot spots or warpage of the flywheel and pressure plate; it won't keep the clutch from functioning.
Old Dec 17, 2008 | 05:45 PM
Hahaha, is there an echo in here?
OEM spec replacement .. ... .. stock replacement .. ... ..
You did go a little deeper into detail, though. Which may keep him from buying one from a Honda stealership.
jwhezzy2003
Aug 28, 2008 08:46 AM
peace
Mar 18, 2008 11:22 AM
97 Sleeper
Sep 26, 2005 07:34 AM
JDM_Type-R
Jan 26, 2005 08:48 AM
-[95cxhatch]-
Aug 4, 2003 11:06 PM
