how in the hell do i stop my antenna from coming up?? what wire??
Old Aug 3, 2002 | 04:43 PM
done's Avatar
Default how in the hell do i stop my antenna from coming up?? what wire??
how in the hell do i take my headunit and din out, i already have center console out.. and all of that...
Old Aug 3, 2002 | 05:00 PM
b18bvtec4drteg's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Jordo)
I would just unplug the unit from the rear antenna assembly. Much easier.
Old Aug 3, 2002 | 05:02 PM
Turtle's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (b18bvtec4drteg)
It is the yellow/green wire I beleive, leading to the back of your head unit. Look for more information here, or IM me...
http://www.sandmracing.com/santennaswitch.html
Brandon - Who beleives there are a lot of people in Pittsburgh that have this thanks to Matt D and Scott!
Ok had to [EDIT], because Im a dumbazz and didnt read all the way through. Center console out right? Ok, next get your azz on the floor (on your back) and look towards the bottom of the head unit (only look FROM the bottom, on the BACK of the stock radio). There you will find a screw holding the head unit in place, on the back. Hope that helps...again IM me if your having trouble...
[Modified by 401-2001, 9:07 PM 8/3/2002]
Old Aug 3, 2002 | 05:14 PM
Ideal R's Avatar
New User
Exactly what I did!
Old Aug 3, 2002 | 05:22 PM
done's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Ideal R)
Exactly what I did!
how do you do that, what panels need to be off?
Old Aug 3, 2002 | 05:24 PM
Razor's Avatar
look around your trunk and pull back your carpet, and you will see a wire going towards the antenna, just pull it out. thats what i did with my car.
Old Aug 3, 2002 | 07:12 PM
ITR#JohnBasedow's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Razor)
cons in pulling the wire?
Old Aug 3, 2002 | 07:23 PM
nEoMuGen's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (ITR0863)
receptions wise...?
Old Aug 3, 2002 | 08:14 PM
Ferrell's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (nEoMuGen)
id like to know what wire to get my antenna DOWN
Old Aug 3, 2002 | 09:57 PM
done's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Yes it's VTEC)
yellow and green like he said did the trick
thanx guys
[Modified by Jordo, 12:57 AM 8/4/2002]
Old Aug 3, 2002 | 10:18 PM
SoCal ITR's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (401-2001)
Oh man.. site's down.
Old Aug 3, 2002 | 10:19 PM
done's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (SoCal ITR)
yes thats one reason i made htis post with quite anger..
Old Aug 4, 2002 | 06:21 AM
Ideal R's Avatar
New User
Exactly what I did!
It is very easy with the helm manual!
If you have the manual, look at P. 20-92 (1998 Integra version)
You first take off the rear trim panel.
Then You take off the driver rear side trim panel.
Keep in mind that you need to detach the cargo area light before you pull the whole panel out.
I actually just pull part of the rear side trim panel out so I can access the back of the panel.
Then on P. 23-202, you can see a connector connect the battery to the power antenna motor. Disconnect it and you are done!
And for reception... one word, BAD. You still have a little with some channels, but nothing for some of the channels as well. But I don't listen to the radio, but I rather listen to my stereo during a car wash. Also, it gets annoying when the antenna goes up and down, and it will bent eventually due to cruising on highway etc.
Old Aug 4, 2002 | 06:22 AM
Jason's Avatar
Are you trying to make it stay down permanently? b/c I had always wanted to make it stay down only when the CD player was on, I never understood why it worked like that
Old Aug 4, 2002 | 07:05 AM
Ideal R's Avatar
New User
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Jason)
My way is stay down permanently.
If you want to make it stay down only when the CD player was on, just try to connect a switch and mount somewhere near the dash. It is not that hard either.
P.S.: I never understood why it worked like that (up when CD player was on) either...
Old Aug 4, 2002 | 07:28 AM
uNF$@#!'s Avatar
how hard is it to pull out the radio?
you have to take the center console out and shift boot area out to get to it, right?
Old Aug 4, 2002 | 08:32 AM
done's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Soup ****)
its not very hardk, about 14 screws.. hardest screws are the 2 (8mm) vertical ones, on the head unit, once those are out, eveything is easy..
Old Aug 4, 2002 | 10:58 AM
mstewar's Avatar
two words for you: aftermarket headunit.. i ditched the crappy acura radio and put in an alpine.. the antenna is only up when the radio is on, it goes down for CD and when it's turned off..
if you want to make it do this with the factory radio, you have to put a switch in.. there's a how to floating around somewhere on doing this..
Old Aug 4, 2002 | 12:28 PM
Turtle's Avatar
It's very easy, 14 screws is correct (had to do it all in my head, but easy ). Yes you have to take the center console out.
about the
crappy stock radio
This is true, if you WANT to get an aftermarket radio go ahead...you just making your car more obvious and most likely to get stlen. I have an aftermarket sony, but it was GIVEN to me and it looks EXACTLY like stock from outside the window. (I have a radar on the alarm anyways so no peeking ). Anyways long story short...some aftermarket radios will have this feature your looking for. (sorry so long winded!!)
Brandon - who needs to shut up sometimes...
Old Aug 4, 2002 | 03:32 PM
Champ R's Avatar
So most aftermarket radios have the feature for the antenna down when CD is in and up when radio is on? Can you tell or do certain brands (alpine, pioneer etc...) do this? Thanks.
Old Aug 4, 2002 | 03:40 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (Champ R)
My Alpine keeps the antenna down while I listen to CD's
Old Aug 4, 2002 | 04:16 PM
Jason's Avatar
Default Re: how in the hell do i stop my antenna from coming up?? what wire?? (ReBornGSR)
yeah, I know this, as I had changed out my headunit before...I was just saying thought about the OEM one
Old Aug 4, 2002 | 05:08 PM
sackdz's Avatar
I just yanked my power antenna and connected another antenna wire to run under the panels
Old Aug 4, 2002 | 08:40 PM
mstewar's Avatar
yep, alpine for sure.. i would assume most other decent brands do as well..
Old Aug 4, 2002 | 08:44 PM
Bob#455's Avatar
Try one of these
