95 Accord EX sensor location(diagram needed)
The codes that I got were these.
1.Heated oxygen sensor
2.Egr valve
3.Barometric pressure sensor
4.Ignition output sensor
5.Speed sensor. (that I have already replaced)
My question is, Can someone help find a diagram so that I can find these sensors on my car. I have tried google but found nothing. If anyone has pictures that would be great. Thanks for any help
2.Egr valve
Just from seeing the Baro sensor in your list I would lean towards you needing a new ECU. The baro sensor is mounted to the ECU so your not goign to be replacing that without replacing the ECU. If you have a friend with the same ECU try plugging that in and see if that clears up your codes.
Thanks for your response. I dont have anyone around me that has an accord. So i will have to buy one. One more thing The check engoine light does not come on untill about 5 or 10 miles. When the light comes on you can start hearing a knoock (that sounds like a rod) at 2200 rpm. in every gear. 2100 no knock.2300 no knock just at around 2200. I had the bearings replaced but it still does the same thing. Would the ecu some how be affecting that? Does the accord v-tec have a knock sensor. I got the car from a guy who blew the motor. I just put a used motor in. But he said before the swap everything was fine
What year & type engine did you replace the blown motor with? Seems like the wiring may be a bit off.
Do you know how the engine was running before you bought it?
Did you have the engine compression and/or leak down tested before you installed it?
P
P
roy ezechukwu
Feb 6, 2014 02:13 PM
dglassmyer
Mar 12, 2012 06:29 PM
r.etheridge
Feb 13, 2011 02:59 AM
