Max-Rev Update / Billet Oil Drain Flanges
These are the Max-Rev manufactured CNC 6061 turbo oil drain flanges that are included in our kits.
If you would like I can sell them seperately for $18.
dealer pricing is availaible if you want to buy lots, as I have lots.
also, guys who wanted D series manifolds, I sent you all emails. If anyone else wants to get in on a D series manifold, email me
d series thread = https://honda-tech.com/zerothread?id=234097
let me know what you think.
I have a few other products that I'll be posting shortly. But I cant say just yet what they are.
turbonetics charges $13 for their cast return flanges.
their billet flanges ( the same as these basically) are $26.
It sounds like a fair price to me. at 30% less than the same thing from someone else.
btw, this is a dolphin safe product.
sorry, just felt like writing something stupid
Rob
Do you just dril the holes and bolt it to the pan? Is there a gasket included? Is it going to leak at all?
Your talking about the oil pan fitting.
What are you talking about? Billet aluminum parts are made from aluminum that was "dug up" as a solid piece rather than a lot of stuff melted together.
i thought that was the drain flange for the turbo?
ok but im not seeing any advantage to the cast piece. It costs more, and the cast piece does the same job. Am I missing something?
art
I do have the oil pan fittings. They're just a couple of bucks. I dont really sell them seperatly , but if you cant get one from anywhere local, I can send you one.
you should use a gasket with the turbo return fittings. They should be supplied with the turbo.
*modified for clarity*
[Modified by shane, 1:43 AM 8/9/2002]
The advantage is that you're buying a nicer part.
it's made from more expensive material to precision tolerences.
and it's shiny, so it will atract kiwis and lemmings
Billet is kind of a generic term.
The way it's used in our industry it tends to imply that a part is machined, usually by a CNC mill or Lathe, out of a solid chunk of material. That material is usually steel or aluminum but isn't necessarily either.
The term has nothing to do with the origin of the material. The 6061 aluminum used in these parts is by no means dug up and then directly sent to us. A billet is usually cold formed by either extrusion or roll press to form the generic shape. it is then either heat treated or chemically aged
by the way Chris, sorry I haven't gotten a hold of you yet. I haven't checked my email for a couple of days. The news is that the manifolds can be done by the 19th. Either I or Curtis will give you a call tommorrow.
Aluminum is aluminum.
my machine shop guys hat it when people say its billit
but weither or not its billit or not, the parts are going to do what the were designed to do....so cool part
Billit HAA what a ghey name for ALUMINUM.....
Is that a joke or are you an idiot?
does billet not contain aluminum
on you would you like a copy of the periodic table?
Rob
hey ill tell you what, i have about 40 feet of aluminum stock and a lathe, would you like me to spin it (on the lathe) for you and sell you some quality BILLET aluminum?
on you
Rob
Rob
on you
Rob
No I have many of my own copies. Billet is a *manufacturing* process. Not a material or element.
Rob
Rob
does it change your oil too?
