No spark...PLEASE HELP
Old Dec 16, 2008 | 03:29 PM
300gtzr's Avatar
Default No spark...PLEASE HELP
So i was driving my 98 GSR home the other day and my check engine light came on after i hit vtec. This usually happens from my spark plug wire popping off of the distributor cap. I got about two miles down the raod on three cylinders and it was fine. When I was going to come to a stop to reconnect my plug wire the engine just cut off on me. I got out checked the wire reconnected it and reset the battery. The car did not start and will not start since then. THe motor just turns over with no reaction of a detonation or half start. I did a compression test everything was fine and in the process noticed that none of my plugs were throwing a spark. I checked the 40A IG fuse under the hood and it looks fine. Another mechanic said that the distributor was fried with out even looking at the car. Before I buy anything I was wondering if anyone on here could help me out?
Old Dec 16, 2008 | 04:06 PM
fcm's Avatar
fcm
Old Fart
Could be the coil or ICM.
Have you checked for power on the black/yellow lead going to the distributor, [with ign. switch in run]? 94
Old Dec 16, 2008 | 04:10 PM
turbo-crx's Avatar
probably fried the coil when the wire fell off.
Old Dec 16, 2008 | 04:28 PM
300gtzr's Avatar
I havent check ed that wire but I will as soon as i get home. I assume that it is supposed to be hot.
Old Dec 17, 2008 | 01:38 PM
MenaceL.A.671's Avatar
might be your coil!
Old Dec 17, 2008 | 04:19 PM
fcm's Avatar
fcm
Old Fart
Yes, the black/yellow should be "hot", [12V+] when ign. switch is in the run position.94
Old Dec 22, 2008 | 11:11 AM
anothersickhatch's Avatar
Default Re: No spark...PLEASE HELP
i have all of my money on the distributor.
Old Dec 22, 2008 | 01:34 PM
300gtzr's Avatar
Coil was bad Burned up from all of the extra current, thanks guys....Thanks again for everyones help.
PapaMoose
27
Nov 19, 2011 03:00 PM
Klutchx22
Nov 3, 2010 07:22 PM
300gtzr
Dec 17, 2008 01:47 PM
300gtzr
Dec 16, 2008 04:02 PM
PerfectTechs
Mar 23, 2008 10:15 AM
