cold air intake + water = :(
Old Dec 16, 2008 | 04:38 AM
nrst89's Avatar
Default cold air intake + water = :(
Im driving home from work earlier and my 00 coupe has a cold air...there was a GIANT puddle not to mention the rain came out of nowhere...i went through...nothing i could have done...i was going to fast...im almost 100% sure my intake dipped into the puddle...after that my car died wouldnt start...pushed it to a friends house and drained the oil...flushed...then new oil and filter and still nothing...when i start it wont turnover...what could the problem be?
please help
Old Dec 16, 2008 | 04:47 AM
Scott.'s Avatar
it happend to me, we tried to push start it, still didn't work. we pulled the head and found out i bent my valves to ****. WOOOT
Old Dec 16, 2008 | 04:50 AM
kp's Avatar
kp
try pulling your spark plugs to check for water in the cylinders. Crank it a few times and blast it all out.
Old Dec 16, 2008 | 05:15 AM
94excivic's Avatar
Sounds like you hydro-locked your engine. Water doesn't compress as easily as fuel vapor and air so you probably have internal damage.
Old Dec 16, 2008 | 05:59 AM
marcs1337's Avatar
you need to pull the spark plugs like Kp said and crank them with them pulled...if that doesnt help you then it looks pretty bad for you...
Old Dec 16, 2008 | 06:18 AM
93LsVx's Avatar
floated the head right off the block, if i were you id just look into a new motor, because if your taking everything all apart, theres a pretty good chance that something isn't going to go back together right.
Old Dec 16, 2008 | 06:19 AM
.Hookedonhatch.'s Avatar
check to make sure your distributor cap and and rotor are not wet. My cousin hit a serious *** puddle two weeks ago, he thought his motor was hydrolocked. I tried my whole distributor, fired right up and ran perfect.
Old Dec 16, 2008 | 07:02 AM
drtysohc's Avatar
I don't see how a bad distributer could possibly give you the same symptoms. If the motor is hydrolocked it won't even turn over.
Old Dec 16, 2008 | 07:15 AM
Mr.Chow's Avatar
+1 on that! you still might be able to save your motor. I saw this done on Top Gear with an old toyota pickup...worked like a charm
Old Dec 16, 2008 | 07:22 AM
dropped_dime98's Avatar
that toyota motor and the honda motor are 2 completely diff things. But yes pull your plugs and turn it over a few times and let the water come out. If that doesnt work you may be out of luck.
Old Dec 16, 2008 | 07:56 AM
EJ8freek's Avatar
That sux. Next time install a bypass valve to prevent water being sucked up.
Old Dec 16, 2008 | 08:00 AM
Dann6968's Avatar
*************If you ever stall your engine due to water, one of the first things you always want to do before you try to start it up is remove all the plugs and crank any water out.*************
Old Dec 16, 2008 | 08:02 AM
lpc805EG's Avatar
well if it ends up u need a new motor....
http://www.hmotorsonline.com/shop/
Old Dec 16, 2008 | 08:06 AM
Uhlig's Avatar
You can claim this on insurance, under comprehensive I do believe. If you don't have comprehensive.... get it! It's covered my **** numerous times, covers hoods flipping up, deer hits, break ins, theft, hail, hydrolocked, smacking road debris on your oil pan and blowing your motor, etc.
Old Dec 16, 2008 | 08:10 AM
Paul-R's Avatar
HYDROLOCK ! yep . this is what you should of done ..... coast your car in neutral threw the water so you won't flood it that sux ..
Old Dec 16, 2008 | 08:26 AM
zeplin's Avatar
I do not believe insurance will cover aftermarket parts. Though, I could be wrong. Anyway, OP, it sounds like you hydrolocked it for sure. Definitely try pulling your plugs and crank the engine over. If this doesnt work I suggest looking for a new engine (and for god's sake install a bypass valve next time! You can never be too careful).
Old Dec 16, 2008 | 09:22 AM
98civdx's Avatar
Master Detailer
some insurance companies wont cover hydrolock.
it happened to me with my h22 accord, had comp put on 3 months later drove threw a puddle sucked water, and because i had an intake insurance wouldnt cover it!!
do the plug thing. if that dont work
i guess its time for ls/vtec, sorry tho i kno how it feels.
Old Dec 16, 2008 | 09:33 AM
tony413's Avatar
call your insurance company and claim natural diseater, usually thats when a tree falls on your car or you hit a deer, in your case just say the front of the car got flooded
Old Dec 16, 2008 | 10:07 AM
The Collin's Avatar
If it starts raining, and I've got my cold air on, I just pop the hood and take the coupler off the TB to make it home. Better than sucking up water.
Or, just run an SRI instead. I've stuck with that lately.
Old Dec 16, 2008 | 10:31 AM
MrFresh's Avatar
Ouch.. thats lame dude.. not much you can do with that situation. good luck
Old Dec 16, 2008 | 10:43 AM
drtysohc's Avatar
Or just push the clutch in when you go through a puddle.
Old Dec 16, 2008 | 11:04 AM
cloud2kz's Avatar
do u have the fender well on your car?
I'm scared to death of hydrolock..especially yesterday.. was on the freeway and the water seemed to splash high, but it seemed ok..
does the filter have to be completely submerged
if you coast through a puddle without stepping on the gas will you usually be fine?
Old Dec 16, 2008 | 11:08 AM
No **** slice, read his post he said "IT WONT TURN OVER". You need air, fuel and spark chief and if water got in his distributor that would prevent the car from getting spark and thus not allowing it to crank over. The cap rotor and distributor itself are the first place to start when **** gets wet and wont turn over. Read a little slower next time
Old Dec 16, 2008 | 11:16 AM
redlinexd's Avatar
short ram ftw!
94EG8's Avatar
Seagull Management
I take "wont turn over" to mean exactly that, seized. Some people take it to mean wont fire, or kick. It really depends here on exactly what the OP mean, is it seized or isn't it?
