crx b16a1 head gasket kit which one?
Old Dec 16, 2008 | 03:11 AM
90jdmcrxdude's Avatar
Default crx b16a1 head gasket kit which one?
I ran into some extra money and really wanted to do the head gasket and other gaskets on my b16a1 in my crx. It has a slight leak so i wanted to get it done soon. When i take the head off i'm going to send it out to get plained down smooth i'm not sure if it is warped or not so just gonna have it worked. my question is what head gasket kit do i get i know its not the 99 si but what is it? I was looking around and all i found was like 94 del sol but that always says its for b16a2 or b16a3 so i'm trying to figure out what one i have to get i would like to just get the kit since that will be cheaper then buying everything one at a time. Thanks for your help.
Old Dec 16, 2008 | 04:07 AM
Furyof4's Avatar
All vtec b series use the same headgasket. same part#
Old Dec 16, 2008 | 07:36 PM
So your telling me that even like the b18 have the same headgasket as the b16? Also i'm trying to just buy the whole gasket kit that includes every gasket for the motor. So i dont want to buy one kit and have only half the gaskets work thats what i'm trying to figure out now.
Old Dec 17, 2008 | 06:53 AM
vtechjunkie's Avatar
yonaka makes a full gasket kit for the b series. top and bottom end. it will run you about two hundred bucks.
Old Dec 17, 2008 | 07:07 AM
ef 991red's Avatar
Well depending on your setup i would go with oem, but if u running turbo or any other compression rate wich i doubt it since u didnt mention i would go with any other like cometic, original is better quality than aftermarket if u running a stock motor with only few mods.dont forget to also change your bolts since is not recomendable to use the old ones since they stretch, ill go for ARP, i just did mine too so.
Part:12251-P30-014 head gasket. And u will have to get every single gasket separate but if is honda is worth it, i got all the parts numbers for all the maintenace if u need them pm me. or http://www.hondapartsdeals.com/
Old Dec 17, 2008 | 10:13 AM
crxfreak1117's Avatar
buy one or a 99 civic si and go to honda and get a factory gasket all b16 headgaskets are the same
90jdmcrxdude
Jan 1, 2009 02:11 PM
WihaSi
May 16, 2007 10:23 AM
808State
Jun 6, 2006 10:54 PM
