2005 Honda Pilot Rear Power Outlet
How do I turn on the rear accessory sockets in a 2005 Pilot. The front socket works fine as well as the radio.
It there a fuse that I should check but I think they are all on the same as the front and with the radio.
Either the CR-V or the pilot has a separate fuse for the rear outlet. I can't remember right off it probably is the pilot. Another thing that seems to happen too is the connector not being on the back of the outlet 100% (soft set) from the factory and it falls off after a while.
