Help!! What is this noise??
Old Dec 15, 2008 | 03:31 PM
92coupe's Avatar
Icon3 Help!! What is this noise??
OK so this noise just happened out of nowhere, and although the video makes it sound a bit deeper, it sounds like either the belt rubbing on the plastic somehow, or possibly the timing belt tensioner bearing is going.
The noise is still there with the alternator belt off so it's not the alternator bearing, and the belt still seems quite tight.
Any ideas would be awesome, hondas are not my forte!
http://s151.photobucket.com/albums/s...=beltnoise.flv
Old Dec 15, 2008 | 03:49 PM
FunnyVictor86's Avatar
you could take the timing cover all the way off and see if it still does it
Old Dec 15, 2008 | 05:05 PM
92coupe's Avatar
Yah that was going to be my next plan. I need to take off the crank pulley to do that though it appears, correct?
Old Dec 15, 2008 | 05:44 PM
P_Adams's Avatar
It sounds like a bad timing belt tensioner. If the video had been of a higher resolution, I might have been able to watch the tensioner side of the belt..... but
Either that or one of the belt guides may be worn also.
What year is this car?
P
Old Dec 15, 2008 | 09:31 PM
92coupe's Avatar
Thanks for your input. The car is a 91, but the bottom end is from a 99 ( d16 I believe), and the top end is from the original 91.
Where abouts are the plastic guides located, just in the cover somewhere?
Old Dec 16, 2008 | 02:31 AM
TheMuffinMan's Avatar
He knows where you live!
Posting in the Civic section would probably help.
Old Dec 16, 2008 | 04:19 AM
P_Adams's Avatar
Under the timing belt cover, attached to the face of the engine block
P
Old Dec 16, 2008 | 12:09 PM
92coupe's Avatar
Oh ok thanks...and woops, I must have read the section wrong...can someone move this to the civic area?
Old Dec 17, 2008 | 12:08 PM
92coupe's Avatar
Update: Drove the car with it like this, the car makes ABSOLUTELY no power until 3000 rpm in which case it goes back to normal....any thoughts?
nicknack25
Apr 10, 2012 11:00 AM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
flat-blk-HB
Apr 17, 2005 06:10 AM
ShaolinRider
Sep 24, 2003 09:27 AM
