LS Swap
Hey guys, ive been doing some searching, and that has answered alot of the questions i havent asked yet, but i still have a couple more questions.
When swaping my LS(b18B1) into my ef 1990 model, i will have to use newer model front spindles. correct? if so will the ones of a 94 del sol work?
Wiring harness( i searched and searched, could not find the answer to my question) Should i use my ls engine harness? or try and use the one thats on the stock motor?
Last question;
Can i swap the rear suspension off my del sol 1994 model (disc brake upgrade) onto my ef?
Last question;
you don't have to swap your front spindles unless you have a std civic or hf crx. if it's a dx, lx, ex, or si it is fine. use the harness on your stock motor. yes the rears will swap however again depending on what 90 model civic/crx you have will determine what parking brake cables you will need.
since it's a dx you will have to convert your engine and chassis harness from dpfi to mpfi. shift linkage will not work. you need to buy a modified shift linkage for a b series motor in an ef chassis. for the rear conversion, yes it will work but you will need 90-93 integra parking brake cables.
i think im going to have rywire make me a harness. after that, do i still have to convert from dpfi to mpfi? if so can i just use loose wire and plugs off of my ls harness?(i have two harnesses)
i dont want to go through all the trouble of buying dseries intakes and what not if im not even using a dseries engine
You need to send Rywire your d-series harness and the Ls harness . He will make 1 plug and play harness out of the 2 for you. Make sure you let him know its a dx and he'll convert it to MPFI also.
whats the going price for a pr4?
i found one on ebay for 115 but it sounds fishy..what do you guys think?
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
^^thats when i raised my eyebrow..
after i read this i started lauging
"EVERY PERFORMANCE PART ON YOUR CAR WILL GAIN POWER FROM THIS ECU BECUASE IT WILL LEARN YOUR CAR AND DETERMINE HOW TO RUN IT BEST FOR MORE POWER!!!! "
i havent bid, and if i do it wont be because of that spoon mumbo jumbo or the fact that it has artificial inteligence and can learn my car..haha..i just need a pr4
Bseries!EF!hatch
May 19, 2006 08:24 AM
