FS: 1995 Acura Integra LS Sedan (5-speed) - $2100
212k miles, green, tan interior, 2 owners.
The good:
- Alloy wheels (stock, 15")
- Power locks
- Power sunroof
- Power windows
- AC works perfectly
- Recent compression test shows the motor is in GREAT shape
- Oil changed 5 miles ago
- Transmission fluid changed 5 miles ago
- Lowered on Eibach Sport springs
- Integra Type R shocks (new less than 20k miles ago)
- Del Sol front seats
- Aftermarket stereo (Pioneer head unit, Sony Xplode speakers)
- Main relay replaced last year
- Brakes brakes (pads and rotors, front and back) replaced last year
- Front brake calipers rebuilt last year
- Front wheel bearings replaced last year
- Front lower ball joints replaced last year
- Sway bar endlinks replaced last year
- Stainless steel brake lines (front and back)
- Timing belt and water pump changed 40k miles ago
The bad:
- Cosmetics. The clear coat is peeling and there is a crease down the passenger side from a light brush with a guardrail by the previous owner. You'll note white marking down the side from this incident. I believe this is only on the surface and will rub out.
- Radiator is showing signs of age, but works just fine.
- I've noticed that the driver's side door lock doesn't lock when you hit the power lock button; this may be a feature, but I'll certainly look in to it and want the buyer to known of it beforehand. It does lock fine when the power locks are activated from the keyhole, though.
Basically, this is a great, reliable people hauler. Before I owned it, it was being driven 120 miles round trip each day without issue. If you're looking to win car shows, this is not the car for you.
Why I'm selling it: Purchased from a friend, but no longer have a need for the car as my commute has gone from 30 to 2 miles recently.
I have owned the vehicle for a few months, but never titled it. As such, I have only driven it the 60 miles to my home following the purchase and a few times around the block after some maintenance I performed. I therefore cannot guarantee everything about the car, but would assume my friend would not have sold me anything with known issues. I will be happy to work with a buyer if an anything arises.
More pictures available at http://www.iammike.org/gallery/?dir=...r_sale/integra.
The good:
- Power locks
- Power sunroof
- Power windows
The bad:
Just a heads up for the door lock issue....its a built in safety feature to prevent you from locking yourself out of the car without the keys. If you pull the handle and hit the lock button on the inside it will lock. Just figured I'd help you out there
Vinny Chase
Jan 18, 2007 07:56 PM
Vinny Chase
Jan 13, 2007 08:23 AM
Vinny Chase
Nov 29, 2006 05:04 AM
