sumping gas tank, few Q's
ill try to keep this simple. car is a 94 integra ls 2dr. ill be making the sump
1. gas tank is mild steel, correct? can i MIG it?
2. most sumps ive seen have two bungs. is one a return or are they generaly both for feed
3. is there any kind of bafling inside the sump or just the holes cutout of the tank's bottom
Yes its mild steel, you can mig it but tig would be alot cleaner. One is for feed on the sump, the return I would use the stock feed line in the top for the new return. For baffling just get a hole saw and drill a few holes instead of cutting the whole area out.
the comp eng sump comes with a template that you can easily draw onto the tank, but its not necessary, just get the whole saw out. my return is where the little sensor is on the left front corner of the tank.
you can easily just order the weld-in an fitting, get some steel from home depot or such, cut it to whatever size you want and weld it together however you like. i've seen sumps made out of the factory pump housing but i dont know how well that would work.
yeah that was the plan i was just unsure why most pre made sumps have two bungs? is it more for people running dual pumps? i like the idea of using the stock feed for return, ill probably do that.
spooledhonda
Sep 16, 2007 07:11 PM
