h23 swap question???
i had an h23 in my prelude and i blew the motor...i put another h23 into the car and i was told that the engine ran fine..when i funally put the engine in and got it running..it runs like garbage it sounds like a lawn mower and it idles at 1500 rpms...also whe nit runs theres a tapping noise and it sounds like its coming from the head.what would you suggest i do to figure this out so i dnt take it to the dealership and get raped??
i got it from a tuning shop it came out of a running prelude just like mine so i nkow the engine is good i checked fo any unusual stuff....but i was told that the valves need to be adjusted?
yeah, valve lash could be off which could cause some of your problems. Honda dealerships usually do a flat rate 1 hour labor charge on valve lash adjustment. Could be a good place to start
1500 rpm idle is weird. It always idles at 1500 cold and warm?
ya ive only had the engine in for a day but ya....hot and cold....n it has like a tap which i think is a valve adjustment issue....i asked them to adjust the valves do a tune up and replace the timing belt and water pump if needed...
