Head questionssssss....
Old Dec 15, 2008 | 12:08 AM
NEWcivicLOVER's Avatar
Default Head questionssssss....
I have a question about head switching. If it is possible what heads are good and what heads can I put on a z6 block? What is required to do this? Any help would be great.
Old Dec 15, 2008 | 12:19 AM
Frost7177's Avatar
any d series will work just depends if you can is wiried for vtec or not and if the head is obd2 or obd1 but you can make any d series head work the most common with the z6 block is the y8 head for boosting.
Old Dec 15, 2008 | 12:29 AM
By switching the heads what internals need to be switched out? Is there anything else like run a b and d series mix or something like that?
Old Dec 15, 2008 | 12:46 AM
Frost7177's Avatar
the flow pattern is not the same for the b series head you need to stick with a d series just go with a y8 off of a ek and youll be happy.
Old Dec 15, 2008 | 12:58 AM
Where do I find the info on how to do this conversion? Cause I have a y8 engine that was given to me when I bought the civic I have. The block is no good but the guy told me the head was good. So what info do I need on how to change the head?
Old Dec 15, 2008 | 12:59 AM
Thanks for your help really preaciate it
kickadog55
Aug 28, 2012 07:37 PM
9DcurlyS4
Mar 8, 2011 12:15 AM
Blahblah718293
Apr 8, 2010 06:45 PM
