cel 2 on a obd0?? 2nd o2 sensor ? WTF
Old Dec 14, 2008 | 11:20 PM
da9blk1's Avatar
Default cel 2 on a obd0?? 2nd o2 sensor ? WTF
running a b16 with a pw0.
and im getting a cel which i believe is a 2.
short flashes,...at first i was thinking 20 due to it being obd0(Eletrical load detector) and wanting another o2 sensor?
well i would like any info that will help me fix the CEL.
thanks alot!
Old Dec 15, 2008 | 12:11 AM
da9blk1's Avatar
searched a bit...seems i need a 2nd o2 sensor(never knew on obd0?!)
anyways...
anyone splice the secondary wire to the primary?
idont have the $ to get a bung welded or another o2 sensor lol!
Old Dec 15, 2008 | 04:31 AM
Stinger EE8's Avatar
OBD0 B16's require 2 lambda's. Connecting them together is NOT recommended. Some people claim it works though. You could use Bre and run a custom chip with 1 lambda.
From Hondata's tech page :
Early VTEC engines use two oxygen sensors arranged to read one cylinder pair per oxygen sensor. The mixture for each cylinder pair is tuned separately. It is important not to wire the sensors around the wrong way, otherwise one cylinder pair will run lean, and the other pair rich. It is also important not to wire one oxygen sensor into both sensor inputs, otherwise the engine will run either very lean or very rich.
Almost at the bottom under the head "Pre-OBD I Engines"
http://www.hondata.com/techclosed.html
Either get your ecu modified or get a second o2 sensor...
minituner
Mar 26, 2016 04:16 PM
J-Civic SIR
Mar 22, 2012 09:48 PM
CRXed
Jan 2, 2007 02:29 PM
Jose-aka-Pedro
Aug 27, 2006 09:41 PM
