aem fuel rail leak
Old Dec 14, 2008 | 10:36 PM
acmoc's Avatar
Default aem fuel rail leak
hey,
I just intalled a aem fuel rail on my d16a6
It is leaking a little from the ends, where you plug the rail at the end and at the fuel inlet on the passenger side.
My question is; How tight do these have to be, I don't want to break the threads or anything. I tightened them a little more and it leaked less, but it feels real tight.
Anyone have experiance with these. They feel real tight already.
Old Dec 15, 2008 | 03:53 AM
CRX Toad's Avatar
Did you use any type of sealant on the threads?
Old Dec 15, 2008 | 07:47 AM
acmoc's Avatar
I thought about it, but they only recommend using the crush washers, and no type of loc tite or anything, maybe I'l' do it anyways
Old Dec 15, 2008 | 08:37 AM
MyHotsh's Avatar
I had the same problem when i installed my fuel rail in my prelude.
I used the washer supplied by them and it leaked, then i used my stock one and it stopped leaking...
Try using the stock washer that was on your stock fuel rail, if it works leave it or get a new one from Honda....
Old Dec 15, 2008 | 09:23 AM
91crix's Avatar
use some teflon tape
Old Dec 15, 2008 | 10:40 AM
daveb91's Avatar
teflon tape on a banjo fitting?
Old Dec 15, 2008 | 02:12 PM
91crix's Avatar
still a fitting still has threads its plumbing
Old Dec 15, 2008 | 02:20 PM
Fresh'86's Avatar
I believe using teflon on a fuel fitting is pointless because telfon gets eatten away by fuel like acid eats flesh. Try reusing the OEM washer if possible.
Old Dec 15, 2008 | 02:35 PM
acmoc's Avatar
It's leaking on the other end. teflon, probably not, maybe blue loc tite, and a lil more torque
Old Dec 15, 2008 | 04:40 PM
rbwdriven's Avatar
not sure you want to do the blue loctite on the fuel rail.
As far as I know the rail is aluminum. Not good to put loctite on aluminum unless you are never gonna take it apart.
loctite on aluminum and threads will cause you to remove the aluminum if you pull the threaded part out again.
We never used loctite where I use to work with aluminum due to that factor. you would kill the part.
Use either teflon tape, thread sealant (ptv) or factory crush washer.
Old Dec 15, 2008 | 05:06 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Technically you aren't supposed to reuse them,
But an OLD oem washer is usually better
than the cheapo ones they supply you..
br8crumb
May 7, 2014 05:19 PM
tooquik209
Sep 11, 2012 12:40 AM
IIVIIoOkY
Mar 21, 2006 03:57 PM
RTW DC2R
Sep 3, 2002 04:39 PM
blackteg
Jul 16, 2002 11:06 AM
