Need tire size advice!!!
No. 215 is simply too wide for a 6.5" wheel. Even if it were physically capable of fitting, the rubbing issues you'd encounter with a 215/65 setup would be nightmarish, not to mention it would throw off your speedometer/odometer DRASTICALLY.
really cuz i have 215s on some motegi rims that i use during the summer and i cant tell any difference in the speedometer.. hmm..
so is 65 the width of the rim, and 215 is width of the tire, and 15 is the rim?
215 is the width of the tire in millimeters. The "65" refers to the aspect ratio. The tire sidewall is 65% the width of the tire (215mm).
This is why as you increase the width of the tire, the numeric value of the aspect ratio will drop to compensate.
15" is the diameter of the wheel.
The 215's you use on the Motegi's are most likely 40-45 "series", thereby allowing for fairly accurate speedometer/odometer readouts. The width of the Motegi wheels, I'd imagine, is also in the neighborhood of 7" which will fit a 215mm tire far more comfortably.
Maybe that doesn't bother you, but that also means you're putting on 5.3% more mileage than you should have to.
http://www.miata.net/garage/tirecalc.html
ArchAngel Sabastian
May 27, 2002 09:24 PM
