Car wont crank after battery change
Old Dec 14, 2008 | 11:38 AM
Inextricabledrvr's Avatar
Default Car wont crank after battery change
1997 SH
Today I replaced my battery as its been a few yrs since I replaced it and now my car wont start/ crank.
I replaced everything properly and made sure everything was tight and secure with regards to the cables and terminals.
Current situation:
1.) Replaced battery
2.) Car wont crank
3.) Horn and headlights are working perfectly fine...internal lights, sounds, etc
Now it wont even crank! I am in panic mode because I have no other means of transportation right now so, anybody with any information how to resolve my problem would be greatly appreciated.
Thank you
Old Dec 14, 2008 | 12:03 PM
mattsnooz's Avatar
loose ground?
Old Dec 14, 2008 | 12:42 PM
Originally Posted by mattsnooz
loose ground?
I checked the ground, made sure positive and negative terminals are in the correct position and it was a no go...
So I decided to hit the alternator with a hammer to maybe think it got stuck. And possibly it would start to crank and it did!
Then it finally started after a couple trys!
Thanks for the input though...
Old Dec 14, 2008 | 02:06 PM
mattsnooz's Avatar
The alternator?? LOLOL.. Maybe the impact rocked the starter solenoid perhaps...wierd
Old Dec 15, 2008 | 04:00 PM
fezz_tec's Avatar
did you by any chance reverse the leads for a quick second? if so you might have blown your fuse. check the fuse's, check your stater fuse first, and work your way around.
Old Dec 15, 2008 | 06:37 PM
I was surprised when it started...haha...I was like wow it actually worked!
BUT...now its officially dead cuz the "hammering" isnt working anymore...LOL...so I had to "pushstart" the car to get it going.
Oh well, its been 6 yrs since i purchased the car and this will be my 2nd minor/major service. (1st was clutch)
How much do these alternators run for?
Old Dec 15, 2008 | 06:38 PM
Yes I did, all fuses checked out ok
Old Dec 16, 2008 | 09:45 PM
fezz_tec's Avatar
do a stater test and a alternator test, check your ground.
03ep3sicivic
Jun 28, 2009 08:05 AM
philkehn
13
Sep 7, 2006 03:58 PM
l34l2l2y
Jul 9, 2005 06:44 PM
97itr86
Dec 26, 2004 07:07 PM
icefire069
Jul 4, 2004 08:54 AM
