Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Radio lock...
Old Dec 14, 2008 | 10:07 AM
lambchop_40's Avatar
Default Radio lock...
I re-programmed my PCM and now I can't use my radio... what is the headache involved to getting my sounds back??!! Aaargh!!!
Old Dec 14, 2008 | 10:46 AM
realazy's Avatar
Does it ask for a code? There should be a card with the code in the manual. There also a sticker underneath the fusebox cover. There are also other spots, but I can't remember them at the moment.
Old Dec 14, 2008 | 11:01 AM
The problem is I can't find the card with the code... I will check the fusebox cover. Thanks man.
Old Dec 14, 2008 | 11:29 AM
J-FAC's Avatar
"If for some reason you do not have that card, you will need to pull the radio out of the dash, and obtain the serial number from the back of it. Then, call your dealership, and they should provide you with the code for your radio.If not, keep calling Honda and Acura dealers until you can find someone that can help. They may require you to come in, maybe with the radio in hand, to obtain the code."
Copied from Miracle in the FAQ thread.
https://honda-tech.com/forums/honda-civic-2001-2005-78/faq-my-radio-says-code-what-do-i-do-1775364/
Old Dec 14, 2008 | 11:37 AM
ejLday's Avatar
god how i hate the oem deck. such a useless piece of sh* but for some reason I miss it's amber splendor...
Old Dec 14, 2008 | 01:02 PM
Why the hell don't I have a white sticker anywhere?!!
Old Dec 14, 2008 | 01:23 PM
The-Kid's Avatar
You can just go to the Honda website now. Still need your serial # and stuff. https://radio-navicode.honda.com/
Old Dec 14, 2008 | 05:00 PM
unevolved's Avatar
Mine was in the glove box, if that helps.
Hey, maybe it's time to upgrade to a new HU anyways.
Old Dec 14, 2008 | 05:21 PM
ejLday's Avatar
I wish mine had a sticker in the glove. I said hell with it, I'm going Alpine
Old Dec 17, 2008 | 03:17 PM
Thanks for everyone's help! I got my radio unlocked and spent nada.
B_Swapped93
Acura TSX
May 2, 2015 12:02 PM
Rowdy Rod
Aug 19, 2011 09:29 AM
