***not going into gear feels like its in neutral***WTF
Old Dec 13, 2008 | 03:10 PM
skUnK2jdm's Avatar
Icon6 ***not going into gear feels like its in neutral***WTF
Hey HT i have a big problem i just finished swapping in my itr motor in my ej! Now i cant find ANY gears and when i find 1,2,3rd the shifter still feels like its still in neutral.
I cant find 5th or reverse......
can you guys help me out on what too look for?
the car drives fine, it takes off fine and the clutch takes off engages fine.
Old Dec 13, 2008 | 03:14 PM
andoxviii's Avatar
Loose shifter bushing. Go under the car and check/tighten the nut that holds the shifter to the shift linkage.
Old Dec 13, 2008 | 03:53 PM
skUnK2jdm's Avatar
yea checked it! its tight why would that cause it not to go into any gear?
Old Dec 13, 2008 | 04:01 PM
mark'd's Avatar
may be a bent shift linkage?
Old Dec 13, 2008 | 04:10 PM
Inliner's Avatar
You have 2 linkages connecting to your trans right? is the bushing at the trans good? is the shifter bushing at the very rear of the linkage any good?
Old Dec 13, 2008 | 04:24 PM
skUnK2jdm's Avatar
The linkage itself looks fine!
Can some provide a diagram for the linkage?
All I have on the tranny side of the linkage is the rubber round bushing,the cover plate and 12 mm screw
Old Dec 13, 2008 | 05:24 PM
skUnK2jdm's Avatar
Any1?
Old Dec 13, 2008 | 05:32 PM
hookedonponics's Avatar
I had a very similar problem. I don't know if it helps at all but 2 of the teeth were broken off my flywheel and wouldn't go into the gears.
Old Dec 13, 2008 | 06:03 PM
longshot's Avatar
u got a ****ed trans IMHO
Old Dec 13, 2008 | 07:35 PM
808Army's Avatar
can u go under car and put it in gear?
Old Dec 13, 2008 | 07:50 PM
skUnK2jdm's Avatar
theres nothing wrong with the tranny, i can shift it from underneath just fine!
I think i might have figured it out, the driverside mount might be the wrong one, and same with the motor bracket. so tommorow i will change out and install the right one
so well see,,,,,,,,,
Old Dec 13, 2008 | 11:43 PM
808Army's Avatar
u need si bracket for driver side. hope works out for u
bleedblue94
20
Dec 6, 2008 04:50 PM
G0crxG0
40
Apr 24, 2006 07:14 AM
clemsonteg
Jan 14, 2006 10:20 PM
tomy_r
Dec 8, 2005 10:15 PM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
