2000 Civic Eletrical Problems after Dash removal
I removed my dash and I reinstalled it. Everything was working fine prior to the dash removal. After dash install the whole front of the end car doesnt work. Example My two headlight hi/lo beam dont work Turn singals dont work in front but does in the rear. Horn clicks and u hear relay but no sound. My Foglights dont turn on either but you can hear relay clicks. I was checking near the fusebox everything seemed to plug up right. I've chcked the headlight fuses and nothing. What plug or fuse or relay do I need change or plug in?. This is on a 2000 Civic Si.
P.S. Interior ,Dome light all that stuff works just fine. Everything from brake lights to stoplights work too. Hazard work too but only in rear.
LTCxD2B
Aug 14, 2012 05:35 PM
mac_24_seven
Mar 13, 2012 03:34 AM
sparcoboi77
Nov 20, 2008 12:55 PM
