Short in Condensor Fan Fuse
Two weeks ago, my air conditioner was blowing hot air. The serviceman discovered that a fuse was blown to the condensor fan and that the condensor fan motor was bad. All was cool and well until yesterday, when the a/c started blowing hot air again. I replaced the fuse and once again I had cool air for a couple of hrs. Now it's blowing hot again. What's causing this?
[Modified by judyj, 4:29 PM 8/3/2002]
sounds like we have the same problem, haven't got around on fixing mine yet though.. but done a lot of reading... for right now, its either i shave short circuit in the relay itself or somewhere around the system..
check your grounds for the AC system, also, check for open wires between the condenser fan fuse and relays... check out handaaccessories.com they got the instruction on installing the AC system, it'll help you to find where all the wirings are at...
FLCivic
Dec 18, 2007 04:37 PM
