What tires to use for my stock gsr eg?
i have a 92 cx with a gsr usdm. basically stock. just wanna know whats a good set of tires out there for my 15" slips. thanks guys.
The size you need is 195/50-15. Assuming from your location you don't experience driving in snow or frigid cold, you can get summer tires to take advantage of their superior performance in non-winter conditions. Here are a couple of recommendations, depending on how you will use them. If this is for daily driving so you care about how much they cost, how long they last, and/or how well they grip in rain, I recommend the Yokohama S.drive ($64/tire at the Tire Rack), which should last you 25-45K miles. If you don't care about those things - IOW if you only care about how well they grip in dry pavement (like if you will occasionally use them for autocross or the racetrack, or if you're big on canyon driving) - then I recommend the Bridgestone Potenza RE01R ($118/tire at the Tire Rack) or the Toyo R1R ($94/tire at tiredeals4less.com ), both of which will probably last only about half as long as the Yokohama S.drive.
