Lighting HID/Xenon kits, Retrofits and Associated Topics
Bad ballast question.? THANKS!
Old Dec 12, 2008 | 07:02 PM
pnoyboldstar's Avatar
Default Bad ballast question.? THANKS!
my cousins drivers side ballast was mounted to a bold on the valve cover (bad idea i know, but i wasn't there). after swapping bulbs and ballasts, we concluded that the ballast is the problem. my question is is the ballast bad because of the vibrations it encountered from the motor? and could it be replaced.? it tries to ignite the bulb, but just flickers then shuts off.. any help is appreciated. thanks.
Old Dec 13, 2008 | 04:10 PM
rnacion's Avatar
Bump, same problem here!
Old Dec 13, 2008 | 04:16 PM
Jas9848's Avatar
there a loose connection inside the ballast. you need to get a new one. try mounting it to the frame so it doesnt happen again
Old Dec 14, 2008 | 10:07 PM
ejLday's Avatar
don't mount your ballast in an area prone to vibration
patrickstar
Lighting
Jul 10, 2009 04:12 AM
kyw3
Jan 4, 2009 04:32 PM
HA0LEFIED
Lighting
Nov 28, 2007 04:54 AM
B18CR-X
Aug 5, 2004 12:08 PM
InTegRa
Apr 16, 2002 01:17 PM
