FS: B16 Block Semi-Built for Boost and Bare LS Block WI
I am located in Verona, WI. I would prefer to sell local but will ship at buyers expense. Plus 3% for PayPal. Everything sold as is.
Selling becuse i am going stockish.
Semi Built B16 Block SOLD
Block has about 570 miles
Block:
-Since first run i have been using Valvoline 5w30, honda coolant, and honda oil filters and has had several oil changes
-I wiped the cylinders down with oil and have kept the block covered since the head was removed(thats why you can see oil in the cylinders)
-Just run for break in with NO boost
-Built by Performance Engine and Machine in Middelton, WI
-Cleaned, Resurfaced, Rotating assembly balanced, Bearings coated, Pistons thermal coated
-9:1 Mahle Pistons
-Eagle Rods
-Race Engineering Block Guard
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-New Bearings and Thrust Washers
-ARP Head Studs
-All timing covers
-All new gaskets and seals
-Will come with stock crank pulley, not the Fluidamper
-New Thermostate
-Doesnt come with a knock sensor
Bare LS Block $75 OBO
Should be stock bore, but i only used a dial caliper to measure. It has been cleaned and had a hone run through it. Comes with a crank that will probably need to be ground and polished.
(the one on the left)
Thanks for looking. Please BUMP.
Block:
-9:1 Mahle Pistons
-Eagle Rods
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-ARP Head Studs
-All timing covers
-New Thermostate
