NJ FS: 3" Turbo cat-back Exaust for 94-01 Integra $175
I have a full 3" cat-back exaust. It's a direct bolt up to earlier model gsr's with the shorter A-pipe. Will fit other integras if you replace your cat or cut down the exhaust. In other words, it's a little long for other models.
The cat has a 3-bolt opening that's a smidge smaller than 2.5" that expands to 3" so it will bolt up to a stock cat or 2.5" downpipe like I used.
If you use a 3" downpipe, you have to cut the exaust and weld on a flange.
Includes a silencer.
Mint condition except for a scrape on the bottom of the canister.
located in north jersey
3" OD
The Reducer so it will bolt up to stock cat. Only Place It Isn't 3"!!!!!!!
3" OD
96ex
May 2, 2006 01:00 PM
CROM
Mar 16, 2003 03:24 PM
