Removing Paint from Wheels
Old Dec 11, 2008 | 07:26 PM
DA-Knee's Avatar
Icon2 Removing Paint from Wheels
ok..so i have some LS Mesh on my DA...
they were powdercoated silver/gray...
my friend had them for a while and he was ableto remove some of the powdercoat with acid(???)
so yeah..i would like to know a way to get them back to stock color
PLS HELP thankx
Old Dec 11, 2008 | 07:55 PM
=honda4life='s Avatar
Aircraft Remover
Here is a link that is in the FAQ. You should always look there before asking questions. Majority of the time you will find an answer
https://honda-tech.com/forums/wheel-tire-56/9658-faq-how-paint-your-wheels-1356908/
^^even uses LS meshes!
Good Luck
Old Dec 12, 2008 | 08:39 AM
DA-Knee's Avatar
Well I definitely read that faq before i posted this thread, I must of not been looking hard enough...but on my wheels some powder coat is still there and some of the stock color is visible(ill post pics later on)but doesn't aircraft remover remove ALL the paint(including the stock)?
Old Dec 13, 2008 | 12:29 AM
black_EM1's Avatar
Community Builder
Community Influencer
LS Meshies are polished stock. Aircraft remover takes off paint. You should be fine. If not, repolish them to original luster.
Old Dec 13, 2008 | 12:52 AM
ejLday's Avatar
use auto-strip. I don't care for air craft thinner, doesn't work that well
Old Dec 13, 2008 | 09:16 AM
DA-Knee's Avatar
thanks .
i am aware they are polished stock...there is some GRAY paint over most of the polished areas....
thanks again for the info
Old Dec 15, 2008 | 06:34 PM
JNocon's Avatar
Here's mine, using auto-strip...
Old Dec 15, 2008 | 09:37 PM
tkda's Avatar
i have never seen auto strip. where do you guys get it?
Old Dec 16, 2008 | 06:01 PM
JNocon's Avatar
I bought mine @ Wal-Mart last year, like 10 cans and used up 5 already. They discontinued that product and replaced it with the Aircraft can. I haven't used the Aircraft, yet, cause I haven't used up my last 5 cans of Auto Strip. But, eventually I will!
Old Dec 18, 2008 | 06:43 AM
rnacion's Avatar
Any heavy body paint stripper, or aircraft stripper when used with a wire cup brush with a drill and a wire brush will pretty much get it all done in one go.
Old Dec 18, 2008 | 09:10 AM
r.wright's Avatar
i am about to try this stuff today:
http://images.orgill.com/200x200/3883873.jpg
ill chime in w/ the outcome.
Old Jun 1, 2009 | 04:47 PM
randomtask77's Avatar
Default Re: Removing Paint from Wheels
Wow, you bumped a half a year old thread to post that?
But just to add to the thread, I've been reading that gasket remover by Permatex works pretty good as well. I want to try it out, just can't find it readily available. When I find the stuff, I'll try it out and hopefully get to post the results.
Old Jun 1, 2009 | 10:12 PM
da9hoezay's Avatar
my post ahahaha
Old Jun 2, 2009 | 08:39 AM
DA-Knee's Avatar
this thread is over with...i had seen a picture of somebody using the aircraft paint remover.
The picture was in the state of the paint dissolving.. i assumed that s how it looked after...
I have polished my rims to pimp status ^_^
Sepulveda87
Aug 25, 2014 03:18 PM
92LXcb7
Aug 15, 2012 02:31 PM
98greensi
Dec 17, 2008 03:56 PM
Mr.Nasty
Apr 16, 2007 06:38 AM
JDMlyfestyle
Mar 16, 2004 04:49 PM
