egr
Old Dec 11, 2008 | 07:16 PM
petercampusa1's Avatar
Default egr
where is the egr vacuum solenoid located on a 1992 accord lx?
Old Dec 11, 2008 | 07:38 PM
hondadude's Avatar
How many more new threads are you planning to start on this one problem?
When the ifno gets scattered thru several posts, it may hinder your getting solid diagnostic info.
To answer your question; The control solenoid is in the box on the fire wall.
You can follow the vacum line back to it. If you want to try to clean it out use brake clean, because carb cleaner may melt/soften the plastic.
That solenoid vents and switches the vacum.
I'll just assume you followed the advice of Mr Yamadas post?
Old Dec 12, 2008 | 10:53 AM
Duane_in_Japan's Avatar
Try this.
File Type: pdf
d16sandrail
Apr 8, 2010 01:33 AM
dleccord
Jan 1, 2010 05:24 PM
infinkc
Jul 29, 2009 08:47 AM
skingfreak
Audio / Security / Video
14
Sep 15, 2006 06:04 PM
djsire
Jun 8, 2006 05:44 PM
