WTT: 96 240sx SE pearl white -NY-
Old Dec 11, 2008 | 06:28 PM
stupendousdanny's Avatar
Default WTT: 96 240sx SE pearl white -NY-
96 240sx pearl white SE 150k~ miles
engine
sr20det - ceramic painted all gaskets replaced except headgasket(have 1 oem extra and one power enterprise metal multi layer gasket), intake manifold beadblasted cleaned thermal gasket installed, nismo motor and transmission mounts, spl clutch pivot ball, nismo slave cyl for clutch, clutch damper bypass braided steel line, act heavy duty clutch kit with new nissan tob, act streetlite flywheel, hks copy tubular manifold, tubular o2 housing, taka braided coolant and oil lines for turbo, hks step 1 264 cams, greddy fmic kit, walbro 255lph fuel pump
ecu - stock sr20det ecu and apexi power fc djetro ecu
flex a lite 220 twin fans, mishimoto radiator brand new nissan radiator hoses, oilpan heater hose kit from heavythrottle, brand new s14 water pump, new belts, yashio factory okachan water temp gauge
braking
brembo front brake calipers and machined adapter bracket calipers have endless pads i believe
spl braided front and rear brake lines
wheels
work emotion xd9 18 x 8.5 +28 with falken 615 245/35/18 with 5k~ miles prob less
mutegi openended lug nuts
circuit sports extended lug nuts 20x
suspension
tein drift coilovers fully adjustable
custom 3' full exhaust no resonators
circuit sports rear upper camber arms
defi imperial gauges white face with control unit - egt,boost,fuel pressure
will also include 5k hid kit prob more stuff i cant remember
bad : radiator support is slightly tweaked, motor and transmission isnt in the car and needs to be wired(I have an uncut sr20det harness and ka harness is still in the car) one drivers side rear wheel stud is stripped but 20 new studs are included
pretty much everything is brand new or close to new had good compression on the motor when i tested it. If you are looking for a drift car project for the winter this is the car for you. I am broke and I need something to drive bumming rides isn't fun anymore. All you need to do is get a bigger turbo something like a gt2871r and you are looking at 350-400hp. All the hard work is done and ready to drop in wiring can be done at places like wiringspecialties.com motor is drop in no fab work needs to be done.
Looking for a rsx-s would want to do a straight trade since I'm a broke art student don't care what color just not the orange one.
feel free to throw me offers on other cars
car is in suffolk long island
You can reach me at stupendousdanny@gmail.com which is the fastest way since I check my email often on my iphone.
Thanks for looking
Old Dec 16, 2008 | 10:00 AM
bump
Old Jan 29, 2009 | 07:25 PM
pavilionlivin's Avatar
Icon3 Re: WTT: 96 240sx SE pearl white -NY-
Trade?
http://hondamarketplace.com/showthre...1#post37211141
acerulz
Transmission & Drivetrain
Nov 10, 2012 04:41 PM
artevo9
May 5, 2009 02:45 PM
96integraGSR
Aug 10, 2005 10:24 PM
toohotcivic
May 27, 2005 11:25 AM
