how to put aftermarket tachometer in cluster (Ek)
ive been seeing this around and i wanted to ask how do you guys do it? i need to do it to mine cause A my redline is way to low. B i dont want another cluster in my car.C i dont want a 5inch tach mounted on my dash.D it looks awesome and its gonna do exactly what i want it to do read correct rpm`s/redline any help would be greatly appreciated help me out pm me if you have any info its for a 96-00 civic thanks.something like this
http://i124.photobucket.com/albums/p...y/DSC08578.jpg
if you dont have any info on this dont come on here to flame or mess the thread up.
thats a straight up custom job but i would do it somthing like this:
get a donar cluster and take it apart...im sure you can find the 3 or so wires that go to the tach, just rewire them into a new one of the right size and epoxy that bitch in there.
As freakasis said, this is a custom job done, just find you a cluster that has a stock tach in it take it apart, put the aftermarket tach in that is the same size and wire the wires in for it.
take the front bezel/cover off. there are small bolts ran through the flexable pc board on the back of the cluster. remove these and the gauges will come right out. then you can use abs plastic or whatever the hell you like and make a ring out of just like the carbon ring in your picture.you will have to be creative and mount the ring in your cluster and then mount your new tach in it. then solder the wires from the tach to the correct locations on the back of the pc board for its switched power, ground, illumination, and tach signal. also when choosing a tach you will need to find one that will work within the mounting depth that the cluster cavity provides. if not you will run into problems with your pc board being in the way, and you pretty much need it for the rest of the gauges to work.
V.MoMO
Sep 12, 2010 08:44 AM
Top-Fuel
May 31, 2005 06:22 AM
89DXDann
Jun 4, 2004 11:38 PM
