Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 crv problems
Old Dec 11, 2008 | 02:34 PM
EthanB's Avatar
Default 2000 crv problems
My sister in-law just purchased a 2000 honda crv about a month ago. Already she has been noticing abnormal noises. A scraping/squealing noise from the timing belt side down low. And also when realtime kicks in scraping/howling noise. Any hints?
Old Dec 11, 2008 | 02:35 PM
Jas9848's Avatar
a/c compressor or tensioner bearing possibly. what is "realtime" if you're talking vtec, a 2000 crv doesnt not have that.
Old Dec 11, 2008 | 02:40 PM
EthanB's Avatar
Realtime is the part time 4wd that kicks in when the front wheels slip.
Old Dec 11, 2008 | 02:42 PM
Jas9848's Avatar
ahh ok. id check the a/c compressor and tensioner bearings
Old Dec 11, 2008 | 02:47 PM
EthanB's Avatar
Could it be an engine bearing? It sounds like it's down lower than the a/c.
Old Dec 11, 2008 | 02:51 PM
EthanB's Avatar
I think the 4wd noise is the differetial lube. Maybe, I really don't know. I am kind of researching a I post.
Jas9848's Avatar
could be. the a/c compressor is at the bottom for the most part. below that is the oil pan. ive dealt with alot of noise complaints in my time as a tech and its never what it seems except sometimes. you have to do some work and start removing belts and see if the noise goes away or changes.
Old Dec 11, 2008 | 02:52 PM
Jas9848's Avatar
the rear diff usually only makes noise on turns and usually can be fixed with a fluid change. the front diff is lubed by atf
Old Dec 11, 2008 | 02:58 PM
EthanB's Avatar
I drove it tonight and it is snowing pretty good (or bad) and the howling 4wd noise only happens when the front tires slip. It's quite fun to drive in the snow, true honda drift.
Old Dec 11, 2008 | 04:33 PM
EthanB's Avatar
Waterpump?
Old Dec 13, 2008 | 06:28 AM
StokelesS_g2's Avatar
I've had mine howl a little bit before, but I got the diff. fluid changed and haven't heard it again.
I've heard that the rear diff. has alot of problems, so change the fluid before it's too late.
Old Dec 14, 2008 | 08:09 AM
ef4dr's Avatar
what fluid do you need to use for the diff? mine has been making the same noise lately on sharp turns and when the front wheels slip
Old Dec 15, 2008 | 01:47 PM
fun4door's Avatar
i've got the same problem, rear diff oil change they said, but then they want to charge an arm n leg, i called royal purple for type of oil i can use, they said 75/90... any comments? should i do the oil change myself in the rear diff?
Old Dec 16, 2008 | 08:47 AM
bamboosted's Avatar
I change the diff fulid twice to three times a year. All you need is 1.5 to 2 qts of dual pump fluid. Its availible at all honda dealers. I pay about $7 a qt so i spend just under 20bucks to save my diff from making nosie and prob a good thing for it.
Old Dec 16, 2008 | 08:58 AM
www.megameet.org's Avatar
NO, only used honda's dual pump fluid for a rear diff.
Old Dec 17, 2008 | 08:00 AM
Import Driver's Avatar
He said the FRONT diff is lubbed by ATF. He did NOT say the rear was.
Old Dec 17, 2008 | 08:59 AM
My Trans is lubed with Honda MTF, LoL.
Old Dec 20, 2008 | 01:43 PM
old no.7's Avatar
Do not use 75/90! Only use Honda dual pump fluid in the rear differential. If it is really noisey you may have to change the fluid twice.
Old Dec 25, 2008 | 09:26 PM
jaqes's Avatar
Default Re: 2000 crv problems
My Doughter got in her 2000 CR-V and started it up, she heard a rumblin noise then the engine raced for a few seconds, then the check engine light
flashed four or five times then it stayed on. I looked at the owners
manual and checked the gas cap, which was ok. I guess it's probably a
sensor that has something to do with the emmision control system.
Have any other CR-V owners had this problem? Is it worth trying to fix
myself or should I just take it to the dealer? The car is out of
warranty so if I take it to the dealer I hope it wont be too expensive,
I figure it will be at the bare minimum $100.
nabil7
Honda CR-V & Element
Nov 8, 2014 02:52 PM
gansogb
Acura TL, RL & ZDX
Mar 3, 2010 06:08 AM
ujhonda
Apr 26, 2009 04:56 AM
dlazic
Jul 1, 2007 07:12 AM
