will clutch fluid flushing fix this issue?
I got a b16a2 with hydro tranny, no problem with the trans no grinding or anything but under heavy load my shifter dosn't **** smoothley like it did befor.
I think i may have got air into my clutch resivor and its dirty looking.
My question is if i bleed the clutch and change the tranny fluid do you think this will work to fix my issue?
the shifter only wants to get stuck between 3-4 4-3 at over 4000rpms, Could air in my clutch line be causeing it not to engage as it was befor.
Any help would be great. I tryed to search the site but i keep geting a million errors on that crapy search bar. Thanks for any help
Just bleed the clutch and see what happen, it's very very easy to bleed it.
yeah im going to do that and see what happens becuase it was a real dark color deff not clean and if air got into it flushing it will solve that problem and I'll just have to go from there. I found a DYI link on how to do it seems like a 20 min job
and $10 bucks hope all will work for me
