z6 mani on y7
Old Dec 11, 2008 | 09:35 AM
SilverDEj6's Avatar
Default z6 mani on y7
Can a Z6 mani bolt to a y7 head, i have read people putting y8 manis on y7, what all will i need to do to make this work without throwing engine codes??
Old Dec 11, 2008 | 09:44 AM
pinks11's Avatar
It will throw a code if your car is 96 on up and OBD2. Since the z6 mani is obd1 and your car + motor is OBD2, it will cause some codes to pop up for sure.
SilverDEj6's Avatar
what all do i need to transfer to the z6, tb sensors etc...
Old Dec 11, 2008 | 12:17 PM
94EG8's Avatar
Seagull Management
You need to use a Y7 or automatic Y8 throttlebody and block off the IACV on the back of the manifold. It would be a lot easier to simply use an automatic Y8 manifold that will bolt right up and require no modifications.
Old Jan 30, 2009 | 03:34 PM
Black96Hatch's Avatar
Default Re: z6 mani on y7
ok so ur saying i can get an auto y8 intake manifold and swap it for my manual y7 manifold with no modification at all?
Old Jan 30, 2009 | 03:56 PM
94EG8's Avatar
Seagull Management
Yes, remember that '99 - '00 IMs used air injection and should be avoided.
92civicsi05
Apr 13, 2005 11:47 PM
murmur9
Aug 27, 2004 09:50 AM
92civic_eg
Aug 18, 2004 06:24 PM
Agent Daimon
Aug 28, 2002 05:50 PM
