eagle crank for gsr good or no
OEM or nothing. Almost all of the guys in SFWD (making 800-900whp) are running OEM Honda cranks with no issues. There are several other things you could spend your money on instead of a new crank...
oem x258985685426465
Most of the components in a GSR can handle a substantial amount of power without modification..
plenty of people on here have run upwards of 300 whp on a completely stock engine.. including you right Schister66?
just send in the OEM one for micropolishing and inspection. I personally have never seen an OEM crank break, and I have never witnessed an aftermarket crack out perform an OEM crank.
Depends what your plans for power are with boost. A stock crank can handle any basic boost setup (basic refering to anywhere between 5 an 15 PSI). Stock cranks can handle quite a bit from what i know.
99, aftermarket, break, broke, civic, crank, crankshaft, crankshafts, eagle, good, gsr, honda, integra, ls, problems
