ls vtec
cheaper way is a b16a2 bottom end with ls head .... its called an VTEC/LS .... not as great as the LS/VTEC but just as fun to build ....but you still dont have VTEC and you lose displacement but then your the first one to do it
Really not worth the money unless you're going for an all out (high comp slugs, cams, valve springs, etc) na setup. Else, you'll be spending a thousand+ for 20 ponies.
