Offsets on 15"s and 16"s!
Old Dec 10, 2008 | 10:11 PM
DuK3t3G's Avatar
Icon2 Offsets on 15"s and 16"s!
What would be the best offset and tire size combo to slam a dc teg as much as
possible without rubbin too much?
Old Dec 12, 2008 | 11:33 AM
nsxtasy's Avatar
H-T Order of Merit
Don't use the wrong size tires to lower your car. If you want to lower your car, do so by using suspension parts - lowering springs, coilovers, etc. Use the same sizes as you normally would - 195/55-15 or 205/50-15 for 15" wheels, 205/45-16 or 215/45-16 on 16" wheels.
Old Dec 25, 2008 | 02:53 AM
DuK3t3G's Avatar
Default Re: Offsets on 15"s and 16"s!
What would you consider the perfect offset on the wheels to go along with those tire sizes to get the lowest and flushest look?
Old Dec 25, 2008 | 08:13 AM
slimjimming6688's Avatar
i have 16x7 with a +38 offset on a ek, it sits nicely without scubbing with 205,45 on them, and ther almost at the fender...almost flush.. with spacers they will be flush and i would have to run a smaller tire like a 195/40
Old Dec 25, 2008 | 09:29 AM
r.wright's Avatar
205/50-15 +40 - +42 offset 15x6.5 or 7j ..not too flush and not too sunk in either.
205/45-16 with same offset as well 16x7
Old Dec 25, 2008 | 11:06 AM
marc b18c6's Avatar
a 0 offset with 15 x 8 on a civic EK it's possible for you ?
Old Dec 26, 2008 | 12:20 AM
DuK3t3G's Avatar
Will these sizes also fit a dc2 nicely?
Old Dec 26, 2008 | 09:14 AM
r.wright's Avatar
NO.
0 offset will not fit nicely on either of the cars listed and imo shouldnt be used for everyday usage.
The above suggestions other fellow members and i posted would be best NOT the 0 offset suggestion.
Old Dec 26, 2008 | 09:53 AM
EJ1is23's Avatar
15x7 +35 195-50-15 or 195-45-15's
16x7 +42 205-40-16's
or
16x7 +33 te's with 205 40 16's
Money right there^
Old Dec 26, 2008 | 05:39 PM
yea a zero offset with 16x8 wouldnt be cool for daly driving or tire longevity, if u want to fit 0 offset you would need to role ur fenders, make ur camber look like its broken and stretch your tires, i personally would run a 16x7 with a 35 offset and a tire size in 205,40,16 or a 195 40
this pic is with my car with 205/45/16 on a 16x7 +38 with stock camber and lowered till you can fit only one finger flat between the tire and fender, not too low not too high, clears speedbumps, allows your suspension to travel without scrubbing unless your driving like a madman through bumpy city roads
Old Dec 26, 2008 | 06:11 PM
DuK3t3G's Avatar
Perfect, Thanx!
Old Dec 30, 2008 | 12:33 AM
jdmdc2boi12's Avatar
what size of tires do u guys think this is?
Old Dec 30, 2008 | 04:47 AM
DuK3t3G's Avatar
Dats a sick combo, I wish I can get something like dat for my dc but tire stretching aint safe! Specially for daily driving......
Old Dec 30, 2008 | 05:06 AM
DuK3t3G's Avatar
Can I get the specs for dat combo?
Old Dec 31, 2008 | 05:01 AM
Hood4real's Avatar
16x8.5 +15 frt and 16x8.5 + 10 rear on 205/16/40 can work with a lil fender rolling and a camber kit to be on the different side
Old Dec 31, 2008 | 07:45 AM
high_society's Avatar
Sick JLines bro, they look hella familiar!
Old Dec 31, 2008 | 11:27 AM
thx
Old Jan 9, 2009 | 08:22 AM
Hood4real's Avatar
how much costume work did you have to do to make yours fit slammed????
Old Jan 9, 2009 | 08:53 AM
That's actually my friend Dan's xB, and those are the same exact wheels as the ones on the car you posted. They get around a lot.
All we had to do was roll and pull the fenders a bit, remove the front fender liners, and add a -3 shim to the rear. Also, that xB is on air.
Old Jan 9, 2009 | 03:25 PM
nsxtasy's Avatar
H-T Order of Merit
or
Money right there^
These sizes are REALLY BAD ADVICE. They are good for older Civics, but they are much MUCH too small for an Integra. As noted above, you should stick with 195/55-15 or 205/50-15 for 15" wheels, 205/45-16 or 215/45-16 on 16" wheels.
Old Jan 10, 2009 | 07:01 AM
ef8-dc2619's Avatar
dont mean to thread jack but my friend is thinking of getting 15-7's with a 15 offset for his ef9..would this offset work?
ATLien6
May 24, 2012 08:58 PM
MRDC2
Feb 21, 2003 05:33 PM
hybridreams
20
Jan 22, 2003 05:26 PM
90-CRXSi
Sep 1, 2002 01:59 PM
k.
Mar 5, 2002 09:46 AM
