DC4 Coilovers: Koni Yellow w/ Ground Controls Sleeves or other?
Old Dec 10, 2008 | 09:59 PM
jaykun's Avatar
Default DC4 Coilovers: Koni Yellow w/ Ground Controls Sleeves or other?
I was wondering if the Koni Yellow w/ Ground Controls sleeves was the best route for the DC4 or is there a better full coilover that you guys recommend?
FYI: The coilovers aren't for slamming the car. The car will be used for auto-x and road racing. Performance handling in mind
Thank you!
Old Dec 10, 2008 | 10:25 PM
SlammedDC2teg's Avatar
Get the track kit. To answer the rest of your question. Yes there are a ton of better coilovers. Try Pic select coilovers, Tein Flex or higher. Do some research. In the end it is going to be up to you.
Old Dec 11, 2008 | 07:13 AM
90_EX_Civic's Avatar
koni yellows/GC, are probably the best choice for the price, and a lot of autox guys run this set up.
Old Dec 11, 2008 | 09:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ditto, Koni/GC = best bang for buck when performance is top priority.
Old Dec 11, 2008 | 09:25 AM
johnkilo3's Avatar
Why would you spend the extra money on something like Tein Flex when GC/Koni's give you the same features for much better value?
Old Dec 11, 2008 | 10:27 AM
redGSRguy's Avatar
They are JDM? So you can sport the TEIN doll on your tow hook?
Old Dec 11, 2008 | 12:13 PM
the only reason i can see going the Flex route is that they are cheaper then the higher end Koni's with almost the same performance.
edit* but even then you can get the skunk2's for even cheaper, and have heard that they are better then the flex.
Old Dec 11, 2008 | 02:42 PM
slammedexv's Avatar
Not a chance.
Old Dec 11, 2008 | 03:58 PM
johnkilo3's Avatar
I have heard nothing but bad things about Skunk2 suspension stuff.
Old Dec 11, 2008 | 04:19 PM
Your such a retard.
GC/Koni is a good combination. But if you pick up a basic set, they aint **** and will just be a smooth lowered ride and will cost you 800bucks. Just for a set of custom dampers you looking at 800 and up.
You need something that you can preload and change springs for higher spring rates. And a good set of dampers. You need something you can daily and track. Running any Pic coilovers or Higher end teins will allow you to run different setups for street/track and they come with more adjustablity than a basic koni.
On my buddys Type R we ran several koni shock with custom valving and in the end what worked the best was a set of Tein Race coilovers.
In the end. Its up to you. Thats just my 2cents
Old Dec 11, 2008 | 04:20 PM
Its only a good value for a basic set. If you get custom rates and valving it will cost about the same. With less adjustability.
Old Dec 11, 2008 | 04:30 PM
redGSRguy's Avatar
Your such a retard. Maybe that's why you or your friends would get them for. Keyboard warrior. Cool your jets and let people that know what they are talking about speak.
Lol why so angry. BTW its "you're" not "your".
Old Dec 11, 2008 | 05:22 PM
johnkilo3's Avatar
Your such a retard.
Thank you for an intelligent reply.
Old Dec 11, 2008 | 06:29 PM
NW Classic Honda's Avatar
x2...
Old Dec 11, 2008 | 07:48 PM
I try.
And redGSRguy thanks for correcting my gramar.
Old Dec 12, 2008 | 09:19 AM
jaykun's Avatar
Thanks for the responses everyone. Which spring rates (front/back) would you recommend for street/autox?
Old Dec 12, 2008 | 11:37 AM
this all depends. depends on, what type of sway bar, toe, camber, and ride hight.
joprez
Suspension & Brakes
Jun 8, 2010 03:08 AM
JDMxDB8
Jan 6, 2007 10:52 PM
shawn2394
Mar 6, 2006 09:57 PM
SilverDc2
Nov 18, 2002 08:52 AM
MysteryWagon
Jul 27, 2001 03:06 AM
