LS VTEC Oil Pumps
Old Dec 10, 2008 | 05:21 PM
stevenDAtegra's Avatar
Default LS VTEC Oil Pumps
I'm about halfway into my LS VTEC Build and am about to put my oil pump in but a lot of build logs I see people using GSR oil pumps. My oil pump is from a b16. Will it still work?
Thanks
Old Dec 10, 2008 | 06:14 PM
FULLYBUILT2.0's Avatar
should be fine. i think gsr, b16 and type r should all be the same..as long the oil pump is off a dohc vtec motor...i have a type R on my ls vtec...
Old Dec 11, 2008 | 07:24 AM
squeezedeghatch's Avatar
the gsr and type r have a higher output, and the teeth count is different. which means you will have to use a gsr timing belt.
Old Dec 11, 2008 | 09:11 AM
be18see1's Avatar
pretty sure this isnt true^^. i have a b16 pump on my b20 right now so what does that tell us? all obd2 b series oil pumps are the same. now, a vtec water pump and a nonvtec water pump have a different tooth count so that that at high rpms a vtec pump will not slosh the coolant instead of actually circulating it.
Old Dec 11, 2008 | 03:42 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
You need to match the belt to the water pump - non-vtec water pump = non vtec belt and visa versa.
The teeth on the oil pump are the same for non vtec/vtec.
Old Dec 11, 2008 | 04:21 PM
biggoofy's Avatar
im running a type r on my lsv-t
Old Dec 15, 2008 | 07:53 AM
pmey's Avatar
agree X2
the main cocern is the water pump
K7-1Ktrevor
Oct 3, 2009 11:51 PM
beaneg6
Mar 10, 2009 04:08 AM
bens_redeg
Jul 10, 2004 07:11 AM
Tinker219
May 5, 2003 08:22 AM
X2BOARD
Apr 16, 2002 12:26 PM
