Question Regarding Throttle Position Sensor (TPS)
I've recently upgraded my 88 Prelude to a 2001 5th Gen Prelude w/ vtech engine.
I'm not very knowledgeable about cars but any information you need and can point me in the right direction I'll get it! :D
The other day the check engine light came on after I noticed the engine wasn't sounding quite right.
I took it to my local Honda dealer and the code they got was a
P0122 7 TP Sensor Circuit Low Input
I'm assuming this is a Throttle Position Sensor?
Every Auto part store is unable to find it in their systems.
Honda dealer wanted 1700 dollars to replace the "Throttle body sensor"
I took it back to my normal dealer and all he could find was a $700-800 Throttle body and Sensor part.
I've seen links on here pointing to various TP Sensors but how do i know they will work with mine? Do I have to buy the Throttle body and sensor?
Example website I found for the Sensor listed these:
1997 to 2001 Honda Prelude SiR ( JDM ) H22A
1999 to 2001 Honda Prelude H22A
1997 to 2001 Honda Prelude Type S ( JDM ) H22A
1997 to 2001 Honda Prelude ( USDM ) H22A4
Thanks
Urlryn
Thanks
Urlryn
omni power makes one for your car. Very cheap, reliable. Its about your only option for a new one that wont cost you an arm and a leg.
I bought 3 for $40 each about a month ago on ebay. http://cgi.ebay.com/ebaymotors/OMNI-...Q5fAccessories
http://www.spoonhonda.com/SearchResults.asp?Cat=119
u can download a repair manual for your car here^
my TPS let got a while back to...i just went to junk yard and got 3 for free
...exept u might have a probleme finding h22s in a junkyard...f22s like mine are very common in junkyards
...and well there first one i tried worked an has been ever scince
http://cgi.ebay.com/ebaymotors/BLOX-...QQcmdZViewItem
The auction is closed but you get the idea.
While were on the subject: will a tps that isnt calibrated affect performance. mine reads -8 closed, 89 open. And how the hell are you supposed to check the voltage. I tried but dint know where to stick the probes. I looked in the service man but i dont understand how u can checkk voltage if u disconnect the harness.
It will definitely affect driveability.
yeah freelog using the motes hulog. I know what the voltage should be but how do I test it? And when I "jab" the throttle when its idleing it vibrates for a split second. I do have innovative mounts tho. I wonder if that is related to throttle tip in.
Back to one of my original questions....
How do I tell if i have a h22 or h23 or whatever?
This TPS shows:
1990 to 1991 Honda Prelude 2.0 S B20A3
1990 to 1991 Honda Prelude 2.0 Si B20A5
1988 to 1989 Honda Prelude Si B0A5
1990 to 1991 Honda Prelude Si B21A1
1992 to 1996 Honda Prelude Si F22
1992 to 1996 Honda Prelude S F22A1
1992 to 1996 Honda Prelude VTEC H22
1887 to 2001 Honda Prelude Type S ( JDM ) H22A
1997 to 1998 Honda Prelude H22A1
1993 to 1996 Honda Prelude VTEC ( USDM ) H22A1
1993 to 1995 Honda Prelude Type S ( JDM ) H23
1992 to 1996 Honda Prelude SE Si H22A1
And being that my Lude is a 2001 VTEC
That leaves
And none of those show VTEC like the others....like i said i'm petty noobish when it comes to engines!
Thanks again
Urlryn
This TPS shows:
That leaves
Thanks again
Urlryn
Tip in/out and lift off fuel cut are big TPS-related things.
Urlryn, if you live in US/Canada, your 2001 Prelude will have a H22A4 and you do fall in that list.
That leaves
Thanks again
Urlryn
That leaves
Thanks again
Urlryn
Another question that just came to mind....
I read someplace that Honda rivets the TPS into the Throttle body thats why they are sold as a unit rather than seperately?
This true?
Whats the easiest way to put this back? Normally you just drill the rivets to get them out but I don't have a rivet gun to put them back...what do you guys do?
Urlryn
This true?
Urlryn
I swapped my f22 im to an h23 im on my 92. After i grinded off the tops of the TPMS screws I just pulled the sensor of the f22 throttle body and swapped it over to my h23 throttle body. Then I just just vice pliers to unscrew what was left. I used some parts store screws to secure it to the h23 IM and then called it a day.
Jonie A. Uy
Honda Civic (2006 - 2015)
Nov 20, 2012 03:56 AM
