Throttle Body Question
Old Dec 10, 2008 | 09:47 AM
TonyRomo's Avatar
Default Throttle Body Question
If you have read my other post you know I am having TPS or what the shop says is Throttle Body Issues. I am considering throwing on an aftermarket performance one, such as this one here... http://cgi.ebay.com/ebaymotors/OMNI-...Q5fAccessories
If I do this will the car run fine or will it have to be tuned or anything like that?
I'm not really looking for any gains I just want the f'in car to run right again.
I can't find a used oem one or I would just get that.
Also, will any b-series TB fit my 00 gsr?
Old Dec 10, 2008 | 10:04 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Well, the throttle body probably isnt the problem - it's probably the tps, as the shop mentioned.
You can pick up a tps for about 30 bucks, alot of aftermarket companies make them now.
If you do go with the full throttle body replacement, dont expect much of a power increase unless your intake, intake manifold, and head are all matched to take advantage of the larger 70mm size. No need to tune anything if you have a rather stock engine. If you you do have some work done, then yes I would suggest that you get your ecu tuned to take advantage of all the mods.
Old Dec 10, 2008 | 10:14 AM
TonyRomo's Avatar
I just want the car to run good and I can't find a stock one so maybe I will pick up this performance one.
I already did replace the tps and it continues with the same error.
Here is a link to the post about my tps... https://honda-tech.com/forums/acura-integra-6/tps-issue-2448547/
Integra1990man
Oct 9, 2006 03:32 PM
specscow
Feb 5, 2006 11:48 AM
methodz55
Apr 9, 2005 07:34 AM
