Loud Squeek during cold starts
Just reccently the car started making this loud squeek during cold starts. Sounds frictional, maybe the alternator pulley? No a/c or p/s. I have the Euro R crank pulley and the alternator is relocated to the bottom (innovative mounts) New goodyear? gator belt and an Odessey PC680 battery. lmk if I left any usefull info out.
Starter rebuild possibly? Which other starter works on the H22? I recall there being a smaller one (few lbs lighter) but I forgot which car it comes out of.
ya jas9848 is right on.....i blew my motor in my prelude and im doing a swap this weekend when i go to start it up i got a knock but it runs.....it has that nasty squeal to......its most likely from moisture try and tightne it and see if it makes it still...if its still doin that then change the belt and youll be golden
I'll throw a word of caution out on Gator belts since I had one shred on me after about 30k... Bought it because I thought they were supposed to be the best, but after it went, I decided to go back to OEM. Food for thought.
you should have about 1" of deflection from the belt. a way to check this is to take a straight edge and put it parallel to the belt. then put a ruler perpendicular to the belt and push down on the belt untill you reach the max. deflection.
thanks chiltons manual
meadams314
10
Sep 20, 2010 09:48 PM
Ritchie
17
Jun 17, 2007 10:02 PM
rayho
May 24, 2006 12:32 PM
5GCivic
Feb 22, 2003 03:00 PM
