90 da transmission ?
Old Dec 9, 2008 | 11:17 PM
teggything's Avatar
Default 90 da transmission ?
do th auto and manual trannys heav the same plugs? i am getting ready to do a 5 spd swap on my DA and was wondering if i have to wire the tranny or not
Old Dec 9, 2008 | 11:22 PM
Ricextacy's Avatar
nah u dont. only thing u gotta wire is the rev light i think.
get a manual tranny w/ cluch, pressure plate and flywheel
and flywheel bolts for a MT
and a manual transmission starter.(i dont kno y but they are diff part numbers)
just remove the flexplate, and torque convertor and slap the MT shiet on.
and than shift linkage!
but for all the electrical stuff like to remove ur key in Neutral and having ur rev light to work sounds difficult.
Old Dec 10, 2008 | 03:15 PM
majinsoftware's Avatar
Just need to do reverse lights, Havnt on mine and it pass's Warrants fine. And the Park/Clutch switch.
I just wired the wires together so it starts with out it being in park/clutch in.
Other then that the looms all the same, Highly recommend throwing in some manual cams and a manual ecu tho so its not at the 152hp rated auto. And back to atleast 159hp (gen1)
Old Dec 10, 2008 | 08:47 PM
teggything's Avatar
well i ahve a gsr head for it that i am going to be putting on after i do the 5 speed conversion and work out all the bugs
Old Dec 11, 2008 | 09:47 PM
teggything's Avatar
i just need to know what all needs to go where when i do it. ive read the DA a/t-m/t write up but it doesnt say anything about the transmissions
Old Dec 12, 2008 | 11:14 AM
Bl6da9's Avatar
There is no ECU you for a manual transmission all the plugs for the auto trany on your harness can either be cut off or use one of the plugs and do a wire trace so you can use those wires in your current harness to wire up the reverse lights. Doing it this way avoids the hassle of running more wire through the firewall.
Old Dec 13, 2008 | 02:03 PM
teggything's Avatar
i dont mean the auto ecu plugs i mean the ones on the transmission
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
danwants2btheman
Sep 13, 2006 12:33 PM
GG-SquadDB
Oct 27, 2005 05:04 PM
Jameson
Apr 18, 2005 02:07 PM
bgoetz
10
Aug 29, 2004 09:27 PM
