skunk2 intake manifold....
Old Aug 2, 2002 | 05:15 PM
lilxvtecxpwr's Avatar
Default skunk2 intake manifold....
tried searchin....no luck. anyways, just a couple of basic questions. i have a b18c1 and im getting a skunk2 intake manifold this week but do i need to change the IM gasket? also, i heard the gsr throttle body and cable wont work, is this true? thanx.
Old Aug 2, 2002 | 05:56 PM
POLLO's Avatar
Default Re: skunk2 intake manifold.... (lilxvtecxpwr)
Yes its always beneficial to change your intake manifold gasket as well as your throttle body gasket. The GSR throtle body will work fine as long as you get the one designated for the GSR . As far as the throttle cable bracket on the tb you can still use the stock ones but you'll have to rig it. Here's the easiest way.
b16a/itr throttle body wheel
b16a/itr throtle cable bracket
itr throttle cable
Other opinions are open, i've done this procedure several times and its worked great.
Also are you buying this manifold new ? If so, I want to give you a heads up abou t it. You will receive a compeletely bare manifold meaning. No fuel rail studs or bolts no throttle body bolts/studs, so you will have to remove the stock ones on the GSR IM. Sorry for the rambling but I was very fustrated when I first did my skunk2 manifold installation and since then I've done like 9 of them and its easy, just buy a pack of smokes before you start.
HYBRIDHATCH92's Avatar
yes chang the gasket........as of now im using the stock cable going to swich it soon but for now it works
strongarm1731
Jan 21, 2006 09:04 PM
Rishiras
Jun 24, 2005 10:43 AM
gsr98teg
Dec 26, 2003 10:26 PM
I B Z
May 21, 2003 01:44 AM
smkngsr
Sep 5, 2002 01:27 AM
